Author Topic: Steering box for cross over  (Read 1290 times)
Zamdrang
  • Male Posts: 17
  • Member since Aug '05
« on: May 04, 2006, 07:12:04 AM »
I know this has been covered....I never have any luck with the search engine on this thing.....sorry to go over it again.    :greengrin:
Anyway, im gonna do a x-over setup on my 85.  Ive been searching for a steering box.    I notice on a competitors site they recommend a 86-88 box for the 79-85 trucks but say you can use a 89-95 box if you wish.  Whats the difference?  Any reason to use one over the other?     :confused:
85 4Runner, 4.88s, 33" MTs, ARB, LC(Cam, TB, Injectors, Header), Brake Swap, 89 rear axle, SuperJunk 4" springs for now....
4runner freak
  • Turtle Points: -301
  • Male Posts: 118
  • Finally started building my truck
    • My Build Up
Re: Steering box for cross over
« Reply #1 on: May 04, 2006, 08:04:41 AM »
Quote
Both boxes are mechanically the same, the benifit of getting one of the 89-95(on the right) boxes, is that the input shaft and casing are longer, so when your axle is pushed forward, you don't have the lengthen your steering shaft. With the 86-88 box you have to cut the steering shaft and weld it back together at a longer length(there are other options, depending on the year of your truck).
Hope this helps
« Last Edit: May 04, 2006, 02:08:13 PM by 4runner freak »
Finally got my '85 4runner!
Let the buildup begin!
Working on DUAL-TRANNYS
http://www.pirate4x4.com/forum/showthread.php?t=862345
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: May 04, 2006, 11:03:46 AM »
i have a 86 steering box for sale :eyebrow:
Zamdrang [OP]
  • Male Posts: 17
« Reply #3 on: May 04, 2006, 12:50:43 PM »
Thanks for the info.    IM running an 85 4runner, im I looking at having to cut the shaft for the older box?   What other options are there?
PMd you on the box...
4runner freak
  • Male Posts: 118
    • My Build Up
« Reply #4 on: May 04, 2006, 02:15:30 PM »
Yes.
It isn't that big of a deal, it's just one more thing to do.
Here are a couple valuable links on how to.
http://www.4crawler.com/4x4/ForSale/...irculatingBall
http://www.pirate4x4.com/forum/showt...oto=nextnewest
Last post Dec 14, 2008, 10:53:13 PM
by BLACKDOG
Last post Oct 29, 2009, 02:02:31 PM
by 80YOTA4X4
Last post Sep 17, 2010, 09:36:22 PM
by drayday55
Last post May 23, 2011, 12:47:26 PM
by Jokeass-Wheelers
Last post Jun 02, 2011, 05:00:32 PM
by Jokeass-Wheelers
