EFI CONVERSION HELP
Started by 87_Yotaman, April 29, 2006, 07:14:56 AM
87_Yotaman
I need some help please.
Toy87 is selling the efi stuff from an 87 and I was wondering if this was everything that I needed or if there was something more.  It is going in an 87 Toyota Pickup with an 85 22R in it.
Here is the efi stuff
http://board.marlincrawler.com/index.php?topic=23539.0
Any help is greatly appreicated.
Thanks,
Alex
______________________________________
[     ]_____________|____TOYOTA___[     ]
[___]_____________|_______________[____]
OR
  __                __
(__) l l l l l l l l (__)
whiteman
I dont see any wiring in the pics, and he says "with a partial wiring harness, most of the odds and ends as well"  Does not sound like it is complete.
Unless you get the stuff real cheap, I would look for somone selling a complete system, that is still intact.  And by that I mean all the wiring and vacume lines have not been removed from the manifolds.  Trouble shooting an EFI system is not somthing I enjoy, and not to many do. :twocents:
looks like the important stuff,  i would snag the computer  because they are pricey,  then see what fzj40  has to do your swap
87_Yotaman
Quote from: 79Coyotefrg on April 29, 2006, 07:53:20 AM
:confused:  ???  :confused:
What does fzj40 have?
OR
  __                __
sblacks91
I have done the conversion, it is easier to get a harness from a 89 -93. If you use the 87 harness you will have to splice in the air flow meter along with the coil and igniter=PITA.You will also need an electric fuel pump capable of 65 psi +or-. Also means you have to upgrade your stock fuel lines.
