mass air flow toyota-86
Started by toy80, April 26, 2006, 06:09:22 PM
toy80
hy have problme whit my mass air flow , have modified engin 22re , y have 89 intake ported w v6 injector, they head or planed .10mm and is ported valve , have steenless valve orver size , the block is theyked .05mm , and the piston is over size .40mm , the crank is stroker , y change the piston for a nother model.
but the problem is , on cold start they engin wont start  y push the mass air flow palette more and the motor start ,  motor warmed , engin start with no probleme , the question they have any ajustement for the mass air flow  ?
Ramrod
go back to elementary english class for a while and then come back and ask the question so someone can understand what the hell you are talking about.  Give me a break dude
I think he is foreign.  probably can't speak english too well.
toy80
you have the responce , im from quebec (montreal) dont speak eng
Quote from: Hyena on April 26, 2006, 09:41:20 PM
Quote from: TEAM RAMROD on April 26, 2006, 09:30:22 PM
:tantrum:        you need to learn some manners
toy80  you need to adjust the afm  to accomodate your engine mods,   i cant remember the details but i'll pm a couple guys that have dont this mod and see what we can do
Ramrod
To be a helpful standup guy like I am the way you adjust the airflow meter is cut the silicon that hold in the cap, then loosen the small screw that holds one of the wheels in there and then rotate the wheel very slowly.  It should not take more than 4 teeth off to get what your going for.  turning it one way makes you mixture more rich and one way makes it leaner.  for more info on this mod check on pirate4x4 in the toyota faq under AFM trick or More Power.  My motor is built up very simular to yours but I never did any of that and it runs pretty damn strong so you might have something else wrong
toy80
tanks guy  i cheak for pirate4x4 , and y reposte if any change
toy80
y find this http://www.4x4wire.com/toyota/minutemods/afm/  and now is work very good  , start heavri time  :thumbs:
