Author Topic: Fuse location for dash gauges  (Read 2025 times)
Toygurl
  • Member since Mar '06
« on: Apr 25, 2006, 07:06:57 AM »
Ok here is my new self induced problem.  The aftermarket radio in my truck was possessed and turned on randomly.  So I got underneath the dash and reconnected some hanging wires, blah blah blah and now the radio functions like it should.  In my moment of wisdom I have done something to my dash lights, fuel gauge, turn signals and tail lights.  Where is the fuse that controls these?  I looked to the left panel underneath the dash and none of the fuses are blown, I also looked under the hood on the passenger fenderwell and none of those are blown..............now where do I look? :hammerhead:
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: Fuse location for dash gauges
« Reply #1 on: Apr 25, 2006, 07:21:48 AM »
the fuse for my dash lights is in the drivers kick panel
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Apr 25, 2006, 08:09:49 AM »
:imwithstupid:
actually  i cant helpon this one,  not without being there and using a testlight
twerp
« Reply #3 on: Apr 25, 2006, 10:32:56 AM »
Ok while were asking I've got a horn that dont beep, dome light ,and a heater control light that doesnt work. I know there somehow linked, but even with my Haynes am having a hard time figuring it out. thanks
« Reply #4 on: Apr 25, 2006, 10:40:22 AM »
look at those relays next to the drivers side kickpanel
:think:
twerp
« Reply #5 on: Apr 25, 2006, 07:45:39 PM »
replaced some fuses, horn was bad at the wheel, had to rebend the copper plate thing-a-majig. Hazards work. Need some new bulbs for the dome and deck lamp to see if those are going and errrr Still havent fixed the cig lighter, dont smoke but gotta charge the cell.
 It is now  :beer: time!
« Reply #6 on: Apr 25, 2006, 08:22:35 PM »
my cig never has worked,  but i have another charge port
  • Momentum Man
  • Turtle Points: 759
  • Male Posts: 13,857
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #7 on: Apr 25, 2006, 08:28:36 PM »
Everything on my truck works  :biggthumpup:
Sometimes even if it doesn't look burnt it still may be, double check those fuses.
84_yota_4wd
  • Turtle Points: 219
  • Male Posts: 831
  • Member since Feb '06
  • mountain goat
    • Buy me some coffee
« Reply #8 on: Apr 27, 2006, 10:58:56 PM »
hey man it sounds like you have a short find that and u should be good. it will be wire that is conected to a ground that is a positive if that makes any sence or the electrical tape on one of ur connections has fallin off and it is groundin out on some metel or another wire. hope this helps good luck
Marlin Crawler
Developers of the longest lasting and most successful
Toyota Transfer case, Transmission, and Differential products on the planet
(888) 94-CRAWL / 888-942-7295
Last post Jul 23, 2002, 04:27:18 PM
by 95TacoTruck
Last post Jan 04, 2003, 01:46:55 PM
by ccolby
Last post Jan 24, 2006, 04:44:43 PM
by Brandon
Last post Dec 25, 2006, 11:33:49 PM
by Marlin
Last post Jan 05, 2010, 10:16:10 PM
by BoG-ToY
