Shock Angle
Started by John Doe, April 18, 2006, 11:46:03 AM
John Doe
I have seen and know that while looking from the rear and seeing || is better over / \. How about looking from the side and having the shocks leaning forward / or rearward \ ??? Is it still best overall to see vertical shocks no matter what direction you are viewing them from?
Just a thought that popped in my head, I wont be implimenting this ant time soon.
MiniSimp
Vertical is always most effective.
On a calculator type in the angle of the shock then hit the "COS" button and that will tell you how effective your shocks will be.
For example a shock mounted at 45 degrees will only be 70% effective.
b_ripper8
A good rule of thumb is never more than 30 degrees. Also, your mounting bolts need to be facing the same direction. Like this ! ! not like this ! -
In Progress: 3RZ-FE Swap Underway.
Currently: 87' 4Runner - SAS - 5.29's - welded rear - Dual 2.28 cases - Optima bluetop - round headlight conversion - FZJ80 grill - rattlecan paint job - trimmed fenders - Ranger hybrid springs front - Tacoma hybrid springs rear - schedule 160 drivelines 8" slip front - Marlin's crossmember - disk brake conversion
John Doe
Ok, so it does work both ways. Thanks
