question about a limited slip diff
Started by dieselsmoke, April 16, 2006, 04:23:58 PM
dieselsmoke
I got a carrier that is the limited slip version, question is
is thier an easy way to determine what thickness washes you need?
or does anyone know what the breaking torque is ?
I wanted to have it set up right before I put the 488's in the front.
unfortunatly the guy at the toyota dealer didn't have a clue.
thanks in advance
need some pics  so we know what kind of LSD you have, any markings on it??
dieselsmoke
there weren't any markings or numbers on it. ( thanks toyota )
the guy at toyota looked it up on the computer for a 85 solid front axle and it looked correct, the problem was that it uses washers that range in size from like 1.1mm to 1.9mm and at like 15.00 each I didn't want to buy a dozen or so to find out.
It is 30 spline cause the chromo birfields fit but you can turn them way to easy, however in light of spider gear preload I didn't want it too tight.
I will get some pics posted as well as some measurements
