A tacoma rear is probably wider, but i'd beef it up before you do what your avatar is showing. Otherwise i'd go with a full floater kit with disc brakes and ifs hubs. That would/should give you another 3". (on a 4X rear end, not sure if you can use the same full floater on a 2wd)
You could also look for a Ford 9" out of an early bronco, you would have endless possibilities with a 9". Just for your comfort, there is a guy up here in WA who runs around in the sand dunes, he has a 2wd Yota, 3rd gen, 350 SBC, Auto Trans, and a total chaos kit, using the stock rear axle, that is welded, he has not had a problem yet and he smashes on that thing.
sounds like you want a full floater and front axle from a FZJ80
Glen, did you just skip the top and read the last post? hahaThis is for a pre runner, you know... for running in the dunes and desert, he's got IFS in the front (prolly long arm) of his two wheel drive Toyota. Olemisstoy88 page
Started by Rockhoppa Engine
Started by Dreadnought General 4WD Discussion
Started by KYOTA Toyota Pickup/4Runner Tech 1979-95
Started by THE ROCK Toyota Pickup/4Runner Tech 1979-95
Started by Jarhead Toyota Pickup/4Runner Tech 1979-95
