Author Topic: axle question  (Read 1892 times)
olemisstoy88
  • Turtle Points: -381
  • Male Posts: 521
  • Member since Dec '05
axle question
« on: Apr 11, 2006, 09:15:11 PM »
I have an 88 2wd I need to get rid of my wheel spacers is there a wider axle for me? is the 4x4 wider? thanks
88. 4x2  Total chaos 6.5" caddy uniball kit  Racerunner 2.5 x 14" coilovers on front, 62" deavers, fabbed engine/shock cage, bed cage, roll cage and great frame, complete int., (5) 5x4.5 outlaw II w/235 buckshots <----- parting out! make offer
'84 4x4 . 5 speed 22r  3.5" lift  33x10.5s bfg MTs  Hannamann Glass frontcap, 32/36weber, LCE swirlie plate, Magnaflow,
"Im madder than Toby Keith at a Dixie Chicks concert"
FIREBALL
  • Turtle Points: 190
  • Member since Feb '03
  • Hi Ho Marlin....u talkin to me
Re: axle question
« Reply #1 on: Apr 11, 2006, 10:55:24 PM »
A tacoma rear is probably wider, but i'd beef it up before you do what your avatar is showing. Otherwise i'd go with a full floater kit with disc brakes and ifs hubs. That would/should give you another 3". (on a 4X rear end, not sure if you can use the same full floater on a 2wd)
wa4x4
  • Turtle Points: -310
  • Male Posts: 1,569
  • Member since Jul '05
  • I'm about to tear the curb up
Re: axle question
« Reply #2 on: Apr 11, 2006, 11:12:25 PM »
 :psss: That's him in his avatar jumping his truck...
olemisstoy88 [OP]
  • Male Posts: 521
Re: axle question
« Reply #3 on: Apr 13, 2006, 01:08:41 AM »
yeah i need that real bad. the discs would be great too. I think its reall for looking and to get rid of those spacers. Is the pinion bolts the same or will I have to drill it to fit?
whiteman
  • Turtle Points: 669
  • Male Posts: 1,276
  • Member since Jan '05
    • Buy me a cigar
Re: axle question
« Reply #4 on: Apr 13, 2006, 07:05:30 AM »
You could also look for a Ford 9" out of an early bronco, you would have endless possibilities with a 9".
Just for your comfort, there is a guy up here in WA who runs around in the sand dunes, he has a 2wd Yota, 3rd gen, 350 SBC, Auto Trans, and a total chaos kit, using the stock rear axle, that is welded, he has not had a problem yet and he smashes on that thing.  :biggthumpup:
olemisstoy88 [OP]
  • Male Posts: 521
Re: axle question
« Reply #5 on: Apr 16, 2006, 01:57:43 PM »
Yeah thats the same set up I have minus the sbc, and I use a 5 speed. so I can clutch my landings
S-10 Stewy
  • Turtle Points: 127
  • Male Posts: 161
  • Member since Oct '05
Re: axle question
« Reply #6 on: Apr 16, 2006, 07:50:33 PM »
I have several friends that have those "Shoe box Bronco's" and from what they tell me 98% of them with the 9 inch rear ends only have 28 spline axles so they are obviously the weak link. :eek:  You could up grade to the 31 spline but it will take some $$$ to do.  It does not suprise me that the Toy rear has held up. :thumbs:  I am a firm believer that those axles "will" take a tremendous amount of abuse! :biggthumpup:
It's built Chevy tough with Toyota stuff!
olemisstoy88 [OP]
  • Male Posts: 521
Re: axle question
« Reply #7 on: Apr 24, 2006, 08:05:52 PM »
do ya'll think there would be less stress on the bearings with wider rear wheels? or should i just stick with the spacers?
synwars
  • Turtle Points: 360
  • Male Posts: 485
  • Member since Mar '05
  • Fabbing with Maffy
    • Can you feel the love?
Re: axle question
« Reply #8 on: Apr 25, 2006, 06:33:19 AM »
There would definitely be less stress on the bearings if you swap over to a full floater.
"Don't let common sense stop you..."
Build up thread:
http://board.marlincrawler.com/index.php?topic=11425.0
KEEP IT CLEAN PEOPLE!!! :bat:
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: axle question
« Reply #9 on: Apr 25, 2006, 08:19:25 AM »
sounds like you want a full floater and front axle from a FZJ80
synwars
  • Male Posts: 485
Re: axle question
« Reply #10 on: Apr 25, 2006, 08:35:46 AM »
Glen, did you just skip the top and read the last post? haha
This is for a pre runner, you know... for running in the dunes and desert, he's got IFS in the front (prolly long arm) of his two wheel drive Toyota. ::)
Olemisstoy88 page
« Last Edit: Apr 25, 2006, 08:43:12 AM by synwars »
Build up thread:
Re: axle question
« Reply #11 on: Apr 25, 2006, 09:16:50 AM »
Olemisstoy88 page
:_oops:
olemisstoy88 [OP]
  • Male Posts: 521
Re: axle question
« Reply #12 on: Apr 26, 2006, 12:35:46 AM »
Hmmm I want to get a full floater but cant find em. ALso would switching from 15x7's to 15x8-10s lighten the stress on the bearings if I ditch the spacers?
synwars
  • Male Posts: 485
Re: axle question
« Reply #13 on: Apr 26, 2006, 06:33:51 AM »
Maybe a little because the weight of the truck is now spread across a larger tire surface area, tires DO take some shock out of an impact/landing. Nevermind the fact that it would be safer, as in no chance of spacers loosening overtime.
But I seriously think you'd be better off with either converting your axle to a full floater, or swapping in a heavier duty axle that is already set up as a full floater.
FROR's conversion kit.
Build up thread:
Last post Feb 16, 2005, 06:10:30 PM
by Rockhoppa
Last post Mar 07, 2006, 12:59:13 PM
by robinhood4x4
Last post Mar 03, 2006, 05:44:55 PM
by KYOTA
Last post Dec 26, 2008, 07:40:29 PM
by 93tonkatoy
Last post Sep 24, 2012, 06:10:20 PM
by Jarhead
