rears up front
Started by 86 4runner, March 29, 2006, 09:31:26 PM
86 4runner
im in the process of mixing some leaves for my front pack, but have some questions.
i have a set of 87' rears, a set of 86' rears and a set of 83' rears.
which set should i use the main leaf out of?
the 86' and 87' appear to be the same which takes the bigger bushings in the front and has the rubber bump stop deal on the front leaf clamp.
the 83' is what i was thinking about going with cause it seems easier to work with.
some guidence would be helpful so let me know what would work best.
thanks, i appreciate it
86 4 Runner SAS, 37 inch Toyo M/T's, E-Locker rear, Lock Right front. 30 spline Longs, 5.29's, Dual Cases, Warn XD9000i
89 toy
dont know if you have seen this but check it out rears up front maxing out 18" travel shocks
http://www.4crawler.com/4x4/4R_suspension-III.shtml#CustomSprings
86 4runner
whiteman
That is a good thread, you should add it to the "Links to FAQs and Information"  Thread.  :thumbsup:
AzBearFan
when I did mine I used the three leafs from my 85 rear pack and then the three leaves from my 86 4runner pack cut down.  I ended up with about 4" of lift and all the flex my 14" shocks can handle
86 4runner
are the 85's the same as the 83's
billy hill
I belive that the 83's have more of an arch to them than the 85's do.
official mall crawlin pavment pounder #1
86 4runner
