Power steering in FJ55
Started by fj55tyrant, March 15, 2006, 06:41:56 PM
fj55tyrant
I have moved my front axle forward 4". Making it really tuff to do a normal sagina P/S conversion. I have seen a picture of a 55 with the steering box mounted further back along the frame with the pitman arm pointing forward instead of backward.
Has anyone seen this ????
I really don't want to mount a scout box outside the frame, I believe I have room between the Rad and P/S pump for a box on the framerail. Just need the pitman to rotate opposite the saginaw box.
Thank you in advance,
Norm
I know its UGLY !!
LCOwner
Didn't Ford use an inside box on the early Broncos?  If they did I'm sure is big $$$$
'71 FJ40, 350 TPI/420, 4.70/mini, 60's/5.38/42's, under construction.
'83 FJ60, SOA underway.  Soon to have a Police 350TBI/700R4/.....
Hill Hoppers Central Valley 4 Wheelers - Founding Member
Four Wheel Drive Club of Fresno - #1127
LCOwner
corrupt
thats not a bronco box its 69-79 2wd f-series box put people them on EBs what you want is a             76-79 f-150 or 78-79 big bronco box with the pitman arm pointing forward if you use any other box
and just point the pitman arm forward the steering wheel will turn the tires the wrong way and it mount outside the frame
fj55tyrant
Quote from: corrupt on March 15, 2006, 09:52:29 PM
Corrupt hit the nail on the head with an 8# sledgehammer.
If I can hit the junkyards ( if the snow has melted enough ) I will look for the box style. I was hoping to tap into the vast ammount of knowledge here.
The question is what steering box has the pitman arm facing the front of the rig ???
I know its UGLY !!
corrupt
i picked one of those up at the local junk yard about two weeks ago from a 78' f150 i'm going to use it in my 69' bronco but im putting different guts so it turn the right way the owner before put a 3;1 close ratio nissan box the works good around town but sucks at slow speeds
Hammerhead
If you can't use the saginaw and don't like the scout then you should look at the '79-'85 toy mini or the astro.
The mini uses the stock bellcrank and drag-link and is a very popular mod on a 55.
The Astro box mounts inside the frame and has the pitman pointing forward.  This mod is common on 40s but might work on a 55...
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
fj55tyrant
I am facing the possibiility of being a pain in the azz. Not intentional.   :help:  :help:
It's not that I don't like the scout box. The high steer I ordered has a drag link for a Saginaw FJ40 so If I mount a box outside the frame I need to re-order a longer link or modify the current one I have......
Was hoping to find a box to mount inside the frame with the pitman facing the front of the rig. Hopefully a 4 turn lock to lock box also but that is splitting hairs.
Thank you for all the replys as the battle continues.... :smack:
Norm
I know its UGLY !!
fj55tyrant
1985 Ford 3/4 ton Pickup..... Now to find a pittman arm that has ford on one side and FJ80 on the other..
Thanks for the replies.
Norm
I know its UGLY !!
brc
I did a conversion on a buddies 55 and we used the astro van box and it works AWESOME.  We ordered a high steer kit and just replaced one of the weld in bungs with a standard one and used a rod end.
If you are going to use the ford box, you can findF a tapered drill bit and drill it yourself.
If you didn't sink to much $$$ in the box it is definately worth looking for a ASTRO box.
Just my 2 cents
1999 CTD 2500 Sport TST/MBRP/AFE/K&N and Quadzilla 315's yada-yada-yada
1985 Four runner 5in lift 35's lockers etc.
1973 FJ buggy project INWK 3RZ SM420 Mini Axles and Aluminum tub/cowl building to be light weight
brc
I just went to the pick and pull and yanked 4 more astro boxes to use.  They had a special day all you could carry out for $40.  I think with everything I toted I had to be carrying 400lbs plus.
Let us know how the steering worked out for you
