Ooh, also I know, at least with a toyota trans, if you were to lift the rear of the trans a couple inches (i.e. tilting up the rear of the trans), the shifter bushings and linkage wouldn't be getting any oil because that stuff would be higher than the oil level now. If your 'Migo trans has the shifter at the back of the trans, this will be the same type of problem.
It's the gasket, when you took the shifter out did you replace the gasket, or did you just goober it up with silicon and maybe you did both? I did this with my Samurai and it wouldn't shift at all until I went to Suzuki and bought their gasket and used just the gasket with no RTV. Overfilling should not matter and would only spit out the vent until it leveled off when the trans gets hot. In some owners manuals it suggests overfilling the trans and t-case when flat towing to save the bearings and seals. About the only other thing I can think of besides the gasket is you mis-aliged a shift rod when you pulled the shifter and it is now kinda stuck between gears and another thought would be is, was there a rubber bushing inside the shifter that seats in the top of the trans, if it was worn you may now have the shifter too deep in the trans so it is binding up.
You screwed up, I just did a search and found that you don't put gear oil in the trans or t-case. It recomends 20-50 MOTOR OIL!!http://club.vmag.com/ubb/Forum6/HTML/000737.htmlhttp://club.vmag.com/ubb/Forum6/HTML/000626.html
running too heavy of oil will cause the problems you discribedthere was a guy on there with a 1st gen amigo and said he was running 10w40
Samurai's are the same way, I think the reason with them is that little engine couldn't even spin a gear lubed up with 80 or 90 wt. gear oil.
dang im good
Pays to do your research before hand.
Whaddya think this thread is here for
No, research is done BEFORE adding the wrong oil.
Started by Boheefus Toyota Pickup/4Runner Tech 1979-95
Started by YotaNate Toyota Pickup/4Runner Tech 1979-95
Started by crazymoritz97 Transfer Case/Drive Line
Started by 83rustbucket Transmission/Clutch
Started by zach0786 Newbie Questions
