36" Iroks and frame clearance
Started by J-BO, February 21, 2006, 10:30:55 AM
J-BO
O.k.  just bolted on 36"x13.50" Iroks on 15x10 2 1/2" BS rockcrawler wheels on my 85' Runner.  I am worried about my rear fame clearance when the wheels are stuffed.  As it sits now, I only have 1 1/2" from the sidewall to the frame at the rear.  I know it is going to rub.  Anybody else run this set up and have the same issue?  I guess some wheel spacers are in order.
1985 Toyota 4Runner
22RE, 63" chevy's out back, hybrid rears up front.  36" IROKs, dual stock cases, Lincoln locked rear, and Aussie locked front.
2005 Chevrolet Silverado 2500HD DD/TR
6.6L Duramax Turbo Diesel, 6" Rancho Lift, Edge Juice Attitude Programer, 35" MTZ's.
IronClad
thats normal on a toyota... even with wheel spacers  if you have any sort of flex they will rub.. its no big deal  just letem rub.. or get wheel spacers and gain a little more flex and letem rub
Annihilation  Fabrication
Do you need a Hammer?
J-BO
My junk is pretty flexy.  I am going to swap a 86+ axle in sometime.  I was just dissappointed with how little clearance I had.  Just wondering if I got too crazy trying to fit 13.5's over 12.5's.  Thanks.
1985 Toyota 4Runner
burnyota
IronClad
neop..  12.5's and 13.5's are not wide tires ;)     the frame rubbage is a commen thing..   thats why i cut mine off behind the cab :D   and my junk is flexy too..  back when i still had the rest of my frame  at full stuff i was still able to rub my frame  with fullwidth and 2 .5" bs wheels   ( thats 10" more axle plus  whatever the difference in back spacing was)
J-BO
Quote from: burnyota on February 21, 2006, 03:20:56 PM
:worthless:
I would post some pictures but my transmission on on the floor (the clutch went out).  I am not looking forward to wrestling that trans and x-fer case back up.  I only have wheeled it once with the suspension setup I have and it flexed very well.  Soooooo I don't have any action shots to speak of.  I am shooting to be done in a few weeks.  Got three cans of black and red durabak for the interior and exterior.  Interested to see how that turns out.  Lookin for some seats and to add some tube doors.
1985 Toyota 4Runner
Thomas P
Get an IFS 86-95 rear axle which is 3" wider and get spacers in front to match. You could also get offset wheels and youre good to go.
'14 Camry SE
SCX10 Honcho on roids!
