Author Topic: Trimmed fenders and bigger tires  (Read 3180 times)
79toy20r
  • Turtle Points: -1
  • Male Posts: 276
  • Member since Feb '06
« on: Feb 20, 2006, 11:36:44 PM »
So i just put some 33-12.50 wild country sxt mud terrains on my 79 toyota. i had to trim the front fenders and i rub in the back of the front fender well at full stuff. so i am going to get some f-150 springs for the rear and move the toyota rears up front. Its a decent start.
RustyToy
  • Turtle Points: 481
Re: Trimmed fenders and bigger tires
« Reply #1 on: Feb 21, 2006, 07:10:29 AM »
just get 2 inch shackles from 4wheel online. cost you about 70 bucks.
I'd like to quit thinking of the present as some minor insignificant preamble to something else~~~~~
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #2 on: Feb 21, 2006, 07:21:52 AM »
Get a BFH for the inner fender, even with a lift when the suspension cycles you'll still rub.
SQUIRREL MONSTER
  • Turtle Points: 151
  • Male Posts: 657
  • Member since Jul '05
  • squirrel powered by hampsterous oxide!
« Reply #3 on: Feb 21, 2006, 11:30:32 AM »
you can try sky'd front relocation plates wich make it to where you dont have to beat the hell out of the fender well and theyre only 20 bux! :thumbs: moves the axle forward about 3/4 or 1 inch..... depending on wich way you place them. worked for me.
« Reply #4 on: Feb 21, 2006, 02:30:07 PM »
the 150 springs in the rear will give you a bit more lift, about 4 inches,  but unless your going to go histeer you cant move the axle forward yet :therethere:  sorry
i trimmed the rear of my fender as Rocksurfer said with a 3 pound sledge,  after removing the rusted pieces i replaced it with new sheet metal
untill you get hysteer  this is your only option,
 besides cutting your drag link  or adding a body lift
now  a 1 1/2 -2 inch body lift is fine but dont go over that  or you will have other problems
79toy20r [OP]
  • Turtle Points: -1
  • Male Posts: 276
« Reply #5 on: Feb 21, 2006, 04:32:13 PM »
Hey thanks guys...the hysteer got ordered today. Now i just got to get an ifs box. Do i need a rebuilt one, or can i just go to the local junk yard???
  • Turtle Points: 1174
  • Male Posts: 5,057
  • Crawlin with Marlin
« Reply #6 on: Feb 21, 2006, 04:43:38 PM »
It doesn't matter where you get one, just get one that works properly.  :twocents:
SQUIRREL MONSTER
  • Male Posts: 657
« Reply #7 on: Feb 21, 2006, 08:38:57 PM »
 :doh: sorry, forgot about that...  but if you say that you ordered up a hi-steer set up, that option is reopened again  :biggthumpup:
olemisstoy88
  • Turtle Points: -381
  • Male Posts: 521
  • Member since Dec '05
« Reply #8 on: Feb 22, 2006, 01:20:52 PM »
If you do glass fendars you can clear 2" bigger tire.
88. 4x2  Total chaos 6.5" caddy uniball kit  Racerunner 2.5 x 14" coilovers on front, 62" deavers, fabbed engine/shock cage, bed cage, roll cage and great frame, complete int., (5) 5x4.5 outlaw II w/235 buckshots <----- parting out! make offer
'84 4x4 . 5 speed 22r  3.5" lift  33x10.5s bfg MTs  Hannamann Glass frontcap, 32/36weber, LCE swirlie plate, Magnaflow,
"Im madder than Toby Keith at a Dixie Chicks concert"
Bob Garrett
  • Turtle Points: 7
  • Male Posts: 134
  • Member since Mar '04
  • Lone Star Land Cruisers
« Reply #9 on: Feb 24, 2006, 08:57:31 AM »
If you move the axle forward an inch or so, that should eliminate the rubbing. I've been running with a 4" lift and the axle forward 1" and no rubbing at all with 33x12.50 BFG MTs.
Bob Garrett
95 FZJ80
83 Mini Truck
uglyota
  • Male Posts: 45
  • Member since Nov '05
« Reply #10 on: Feb 24, 2006, 11:39:49 AM »
The hysteer is a great upgrade and will make everything else work out well, but in my experience rears in front doesn't work well by itself...get ready for a little domino effect action.  Plan on building a dropped front spring hanger to keep your pitman off your springs, boomerang shackles, long travel front driveshaft, extended brake lines, and new shock mounts and shocks before you can expect it to work correctly.  But don't worry, it's worth it.
80crawleryota
  • Male Posts: 202
  • Member since Jan '06
« Reply #11 on: Feb 25, 2006, 09:29:35 PM »
what year f150 for the springs
TrikeKid
  • Turtle Points: 782
  • Male Posts: 165
« Reply #12 on: Feb 25, 2006, 09:44:34 PM »
The 88 to 97 body style I believe, most trucks I see with them have years hovering around 90'.
85 Xtra-Cab- stuff and things.
79toy20r [OP]
  • Turtle Points: -1
  • Male Posts: 276
« Reply #13 on: Feb 27, 2006, 03:20:54 AM »
For the f-150 springs i'm not sure of the years, but they are 2.5" wide and i believe they have to be out of a 2wd i think...somebody want to let me know for sure??
Last post May 06, 2008, 06:21:03 PM
by BoG-ToY
Last post Jun 14, 2008, 06:03:49 PM
by WHITE_TRASH
Last post Jul 26, 2008, 10:33:50 PM
by cgbemis
Last post Oct 15, 2009, 12:55:10 PM
by KingofChilli82
Last post Mar 10, 2010, 10:21:14 PM
by brandon95
