Engnbldr's 261 crawler cam vs. the 268 .425
Started by Volcom, February 20, 2006, 12:08:10 PM
Volcom
I plan on running one of these two cams.  I don't have a ton of money to throw into my engine rebuild project and the Engnbldr cams seem to be the most economical for a tight budget.  I am comparing to two cams he offers, the 261 "Crawler" cam or the 268 cam.  This 4Runner is going to be a weekend rockcrawler.  It's not going to see any DD.  I will be driving it to all the trails here in Colorado.  We've got some steep mountain passes and the 22RE isn't a powerhouse.  I know it's not and plan on it being slow up the mountains.
Which cam would you choose and why?  I've reasearched cams on numerous boards until my eyes have hurt and still can't make a decision.
Thanks!
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
unless the stock cam is in bad shape dont waste your money,  the engnbldr cams are just barely over the stock cam if at all
whats the lift of the 261,  obviously  it has 261* duration,  i bet it has .405 of lift,  :thud:   i wouldnt bother ,  you need 430 lift to see any noticeable difference
Volcom
Quote from: 79Coyotefrg on February 20, 2006, 12:15:01 PM
What would you suggest for a 22RE over the engnbldr cams?  Thanks for the reply.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
 Product Information
LC Engineering is constantly striving to improve both the quality and performance of our products. We test our camshafts on the street, race track and off-road. The results are an improved line of camshafts that offer a broader selection of grinds, increased horsepower and higher quality
All LC Engineering Camshafts are ground on new billets, and double heat treated for long life. Each has been designed for maximum torque and horsepower! We can custom grind to your specifications and have a full selection of valve train components.
20R/22R - EFI Pro Camshaft Split Duration
Smooth Idle (1200-5000 rpm range)
Throttle Body, Filter Charger, 1 1/2" Header
                                            Intake     Exhaust
Valve Lash                              .008         .012
Valve Lift                                 455"         455"
Advertised Duration                  285°         290°
Duration @ .050"                     238°         248°
Lobe Center                            102°         118°
Intake Opens           8°  BTDC
Intake Closes         32°  ABDC
Exhaust Opens      45°  BBDC
Exhaust Closes       5°  ATDC
Click Here to view detailed Installation Instructions for this product.
actually  this might be a smoother crawler cam
its a .440 lift
                                            Intake     Exhaust
Valve Lift                                 440"         440"
Advertised Duration                  280°         280°
Duration @ .050"                     230°         230°
Intake Opens         13°   BTDC
Intake Closes         37°  ABDC
Check out www.LCengineering.com for New Products, Tech Articles, Specials & Monthly Newsletters!
yea  they are more expensive than the negineblder,  but they are FAR from stock
i run the 20/22R stage II race cam   .460 lift but it dont really idle smooth  :eyebrow:
Skinny_Pedal
Im an OG
skinny,  have you clicled the link in my sig??  does yours sound that "good"
:smack:  i just read the header of this topic,  the 268 cam has a .425 lift  :smack:
thats not bad
Ramrod
I called engnbldr and asked him which of his 3 cams would be best for my truck and he said I should go with the 268 and I did.  Havent run it yet though
the 425 lift should be decent,  and a step above stock
Ramrod
according to all educated writups I'ves seen on toyota camshaft design it is not so much about lift it is more about the lobe design, espescially the duration and separation.  The motors supposidly cannot handle too much lift with the efi and still pass smog and not have the valves hit the piston
Ramrod
oh yah I just remembered that I read a bunch of dyno charts by grumpy4x on pirate on all the different toyota midrange cams of every company and they were all pretty much the same.  The 268 had about 1avg hp more than the 261 and supposubly ran alot smoother and had a longer powerband also
Quote from: bigbluewillys on February 20, 2006, 07:08:12 PM
well Bigblue,  i dont know about the "write ups"   but from 1st hand experience i can tell you my Lc Engineering stage 2 race cam is just that a race cam,  designed specifically for the 20/22R by LCengineering,  and tested by me,  i ran it in a bone stock 20R and  could pull out to 5500 rpm with ease  befor the cam i was lucky to get 4000 rpm, after a weber carb and LC headers,  i could take it to 6500  in all but 4th gear
when i pulled that engine due to being under water, ( long story)   i installed a stock 81  22R block  and 2 times in a row broke the speedo cable off   after passing the 90mph mark on the speedo
for a short time i had this same engine in my celica  and consistently broke 120 mph
yes   the pistons have to be notched  or you risk bending a valve if you go over 6000 rpm,   which i did at one point, broke the valve off  ruined that head and badly mangled the block  but i'm running the block now, bored .060 oversize  with the cam in another 20R head
i used plasma rings and they take for ever to wear in but after 2000 miles it seems to have more power everytime i drive it
Ramrod
I doubt that cam would work with efi and by the sounds of it I dont think it would work to well for rock crawling
i dont know my weber floods befor i ever get that far  after a 45 degree angle  i have to open the throttle a good bit to keep from flooding out and dying
besides my truck isnt a "rockcrawler"   its a general use,  "crosstrainer"  i guess you could call it
but i can sling even red clay off my tires :driving:
no its not for efi,  but they make one a bit milder for a efi i think its a .440 lift   this cam  a weber, holly  or sidedrafts is a must,
but that 425 lift cam should be a nice step up for a rock truck, and show improvement on the free way to boot
Im gonna go with the 268 in the engine i am rebuilding for James.  If i like it i will put it in my truck too when i eventually rebuild my engine which should be soon since it is running like crap.  hopefully i can dog it out untill after the tin benders jambo then it can do what ever.
Volcom
Quote from: 79Coyotefrg on February 20, 2006, 08:01:18 PM
That's what I wanted to hear, I'll going in that direction.  Thanks for the cam discussion guys  :beerchug:
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
toyo487
I ran engbldrs 268 cam in my 22RE and it gave me a bit more power to get up to speed (bottom end) but didn't really seem to make much difference at highway speed.  I sold the truck and have an 89 extra cab with the 22RE now and I just had the exaust done from the cat back with 2.25" to a 40 series flowmaster, and I noticed that I now have about the same amount of power as the cam gave me on my 94 with stock exaust.  I personally would get a cam with bigger lift because the 268 is so close to stock.
1986 Toyota 4Runner 22re 5spd transmission and dual transfer cases (4.7's in the rear). E-lockers front and rear.
2005 GMC Sierra diesel, compound turbo setup to pull.
   God gave all people talents but the only one who can find them is you.
Volcom
I got it on the doorstep yesterday  :greengrin:   I know it's not going to make a ton of HP but it should help out a little bit
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
kyle_22r
last i checked, EB's cam was 268 duration(durrrr) and .430 lift.
