Author Topic: 3RZFE (2.7L)conversion  (Read 2193 times)
mhemingw7
  • Member since Apr '03
  • 85 bobtail toyota
« on: Sep 23, 2003, 07:04:36 AM »
i have recently came across a rolled 95 toyota t100 2wd 5speed with a 2.7 L 4 cyl engine with about 80000 miles
i am wanting to install this in my 85 toyota with dual cases what is nessasary for this conversion
i am fully aware of the wireing and motot mounts what i want to know is what needs to be done to the trans or bellhousing i have found other sites saying i can bolt my trans right to this bellhousing others say i have to use a taco bellhousing
any help will be appreaciated
« Last Edit: Sep 23, 2003, 07:05:22 AM by mhemingw7 »
living in the desert makes toyotas
a musthave thing . so much desert to crawl in and so few gas stations.
barstow is great, calico and the hammers are both within a half an hour  drive.
mr4x42u
  • Turtle Points: 700
  • Member since Sep '02
  • LOCKED AND LOADED
Re:3RZFE (2.7L)conversion
« Reply #1 on: Sep 24, 2003, 04:01:26 AM »
Use the tacobell housing but bolt you trans to the bell housing as it is stronger then the taco trans from what I understand.Also it takes a bit of work but can be done to get the exhaust to clear the front drive line due to the fact there on the same side..other then that its pretty simple..Mybe mike will chime in and clear the tranny strength question up.. :crossed: :biggthumpup:
Caique Macedo
  • Turtle Points: 7
  • Member since Jul '04
Re: 3RZFE (2.7L)conversion
« Reply #2 on: Aug 03, 2004, 09:20:55 AM »
i did it with a 87 22r reg cab, do you still need info?
kyle_22r
  • Turtle Points: 530
  • Male Posts: 1,233
  • Member since Dec '03
  • yellow beast
« Reply #3 on: Aug 03, 2004, 04:54:45 PM »
t100s had their driveline on the same side as our minis, so the exhaust downpipe from a t100 should help solve that problem.  i think bigmike is using it on his '81
Last post Aug 17, 2005, 08:31:06 PM
by Mark m.
Last post Nov 13, 2005, 10:49:52 PM
by BigMike
Last post Nov 18, 2005, 07:30:03 PM
by oli001
Last post Mar 11, 2013, 01:14:32 AM
by malodin
Last post Feb 24, 2015, 08:02:31 AM
by zippo
