1987 Isuzu Trooper / Marlin Crawler question
Started by RockSlayer, January 31, 2006, 08:46:24 AM
RockSlayer
Howdy all. I have heard a rumor that it is possible to mount up a Toyota Transmission and with that the Marlin Crawler. Can anyone tell me what exactly I need to do this? :dunno:
I got the Trooper for free. :biggthumpup:  I have access to a Toyota 5 speed and transfercase from a mid 80's truck. Not sure which model the tranny is, but I do know that the shifter for the transfercase is located on top of the transfercase, rather than on the back of the transmission. I have the t-case and a Toy front axle at a friends up in Washington. The front axle will get stuffed under the Trooper at some point. Any input would be appreciated.
oddball
I dont know much about troopers, but check out independent4x.com if you havnt already
oddball
Also check on pirate 4x for the Toyota FAQ, they also have an Isuzu section too
he's going to use a toy front axle  :slap:   all you need is a trooper engine to toyota tranny adapter
slayer, is the tranny a cast iron tranny or a alum,   with a plate in the middle
RockSlayer
It's an aluminum transmission with a black steel plate in the middle.
RockSlayer
Quote from: 79Coyotefrg on January 31, 2006, 11:01:23 AM
Where do I get a Isuzu engine to Toyota Transmission adapter? Is this a super secret Marlin product?
RockSlayer
Advanced adapters does not made that product anymore. Strike one. I did find a site where a guy worked with Marlin on putting a Toyota Transmission behind a Isuzu 3.2, ( which I believe to be a GM engine)
Maybe I will have to go to the Tera low 3.0 low range gear set for the Isuzu Tranfercase.
beats me man,  i wonder if the bellhousing from a 3 somthin liter camaro v6  would be a candidate for a conversion
RockSlayer
My Trooper has a 4 banger in it. I don't know if the GM belhousing would work. I might just have to make something up myself. An adapter plate from the bellhousing to transmission and some input shaft manipulation.
I wish I didn't live where we have smog laws. I would just stuff a 350, NP465, and NP205 that I have in my garage and chase down a Klune V, bolt up to it and call it good. Damn smog laws!
