yeah i second the auto zone comment but about you r breaks are you loosing fluid?? cause on my truck the caliperare leaking and that causes the same problem on my truck that you are describing so even if its alittle ass leak it can allo air into your system so check that
yer booster could also be going bad.. when mine went bad i had peddle pressure with the truck off.. soon as i started the truck i had none.. straight to the floor like nothing was connected to the peddle. this is with a 1 1/4 corvette MC too. switched my booster and everything came back
Started by 4rox General 4WD Discussion
Started by Siringo Toyota Pickup/4Runner Tech 1979-95
Started by lilbuddy General 4WD Discussion
Started by DFWFO Toyota Pickup/4Runner Tech 1979-95
Started by kneedownnate General 4WD Discussion
