mitchells very slow build up thread
Started by mitchell, January 14, 2006, 03:23:39 PM
whiteman
Dang man, I havent seen your build before.  Nice looking runner, I love the hummer wheels and tires.  It looks killer. :thumbs:
Quote from: mitchell on January 23, 2006, 08:52:36 PM
it is about 90 mls southwest of dallas fort worth and about 80mls west of waco
which puts in about the center of texas
:aaa:  which kinda puts you in the middle of no where :yikes:
mitchell
going to pick up some chevy spring next weekend for 40 bucks
cant wait to start my bumpers
when ever i get some more time
"A smile on the lips and a hole in the head"
mitchell
started my front bumper
i am useing some 4" x 4" square tubing for the main part
and some 1/2" plate and 1/4" thick angle iron
ive got about $30.00 in material
still need to trim and cap the ends
do some more welding and paint it
and i ordered a 1600 ceramic clutch and brake lines from marlin
hope that doesnt block the radiator too much  :ack:
looks good tho
mitchell
i was thinking of putting 3 or 4  four inch round holes in the front part of it
the sway bar comes off as soon as i do the lift
the stock springs are so sleeper out i think it is better left on
i am still undicided on the lift do i go cheap (chevy rear and rears up front) or do i just go with the marlin or trail gear set up
after i install the new clutch and brake lines the next thing will be the daul case adapter and 30 spline chromos
synwars
x2 :yesnod:
Double rears works fine. Plus moves the axle forward which you'll need to stuff some 38's in those wells. Do it. :clap:
"Don't let common sense stop you..."
Build up thread:
http://board.marlincrawler.com/index.php?topic=11425.0
KEEP IT CLEAN PEOPLE!!! :bat:
burnyota
run the rears up front (or hybrid leaf pack) and the 63" chebys in the rear and you'll be fine...don't think you'll clear 38's though unless you make some hangars....i agree by moving the ft axle foward because the tire will easily hit the rear of the fenderwell at full stuff ...looking good
85 p/u, marlin#208, built 22R on propane, old school longs, 5.29's / detroits, bobbed, chopped, and flopped
mitchell
well i finally got time to finish the front bumper
heres a couple of poser pics  :disturbed:
84_yota_4wd
hey man nice truck dude my name is also mitchell hahas just thought id check ur truck out cause a fell mitchell built it nice truck
Marlin Crawler
Developers of the longest lasting and most successful
Toyota Transfer case, Transmission, and Differential products on the planet
(888) 94-CRAWL / 888-942-7295
dude, that looks great
but that plate below the bumper  you should cut some holes in the upper portion so it doesnt block the radiator
synwars
Maybe he doesn't have cooling issues? :dunno:
Build up thread:
burnyota
mitchell
Quote from: 84_yota_4wd on May 16, 2006, 09:58:03 AM
hay mitchell what up  :thumbs:
Quote from: 79Coyotefrg on May 16, 2006, 10:11:24 AM
i was thinking of cutting three 6" holes in that plate
but i dont have a way to cut three perfect holes right now
i havent had any cooling problems but then i dont drive the truck every day
i'll get around to cutting holes in it one day
Quote from: burnyota on May 16, 2006, 10:30:10 AM
good to see that your back
thanks dude
another Texan :woohoo:
so ryan are you coming up to Hotsprings july 21st
6.72:1
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
laskt9
hey so i just bought your truck from a guy named tim in wisconsin!
