Author Topic: spindle/wheel bearing problems???  (Read 1634 times)
GrenadedToy
  • Turtle Points: 49
  • Member since Jun '05
  • Maatt Daeemon
« on: Jan 11, 2006, 10:35:55 PM »
ok so today i started piecing everything back together on the side of the axle i was rebuilding. i put the wheel bearings in the hub and put it on the spindle. then proceeded to try and put the adjusting nut on but there isnt enough threads on the spindle for the other 2 or 3 things that need to go on. and i double checked that i put the spindle and backing plate on correctly. so i dont know what it could be.. :help:
hudlenutz
  • Turtle Points: 22
  • Male Posts: 220
  • Member since Apr '05
    • My Page
Re: spindle/wheel bearing problems???
« Reply #1 on: Jan 12, 2006, 10:23:41 AM »
when you did the wheel bearings, did you get the races to fully seat against the stops in the hub?  Could just need to beat on it a little more.
GrenadedToy [OP]
  • Turtle Points: 49
  • Maatt Daeemon
« Reply #2 on: Jan 12, 2006, 03:38:34 PM »
ok thanks i'll try that.
ZukIzzy
  • Turtle Points: -113
  • Member since Dec '05
« Reply #3 on: Jan 12, 2006, 03:40:38 PM »
Soft hammer and a couple good whacks it will start on the seat and you can finish it with the nut.
Wayne
GrenadedToy [OP]
  • Turtle Points: 49
  • Maatt Daeemon
« Reply #4 on: Jan 12, 2006, 10:13:48 PM »
ok just to make sure, you put the spindle behind the brake dust shield right? thats how i have it now.
Last post Oct 14, 2004, 09:08:18 PM
by toymachine
Last post Jan 22, 2005, 08:54:15 PM
by KYOTA
Last post Feb 06, 2008, 06:43:52 AM
by crawlerdan
Last post Aug 25, 2010, 08:17:10 PM
by snowplow
Last post Sep 17, 2013, 04:32:43 PM
by OOPS
