I was thinking put the 4.7's In the rear and put the Twin Stick In the 2.28 Crawl Box so I could use stock low range In 2wd. Any thoughts or comments would be greatly appreciated.
I already have two 23 spline Inputs one of them is the Marlin 4.7 Total Spline currently connected to my R151F In the truck, and the other Is a stock Toyota 23 spline that I Installed In a top shift case that had a broken Input.
So you are saying that you've got a complete top shifting 23-spline 2.28 case sitting on the ground right now?If that is true then save yourself some time and just keep the 4.7s in the front case. You've already gone through the trouble of putting a 23-spline 2.28 input in a non-Turbo t/case, and that is just want you need to do if you were to go with Option Two above.Then you would just tear off the 4WD stuff from the 4.7 t/case and then build the Crawl Box from that, and then just bolt your 23-spline 2.28 topshift case right behind the 4.7 Crawl Box. It's a direct bolt on, assuming you build a 23-spline Dual Case (with a 23-spline coupler).Otherwise, you would need to convert your 4.7 case to a top shift, and then tear down that 23-spline 2.28 case and convert it to a forward shift and also build a Crawl Box outta those parts.
TTT Do I need new shift rods since I will be changing the 4.7 case from a forward shift to a top shift? and these shift rods will have to be ground for 4.7 correct? Thanks In advance. Worley
Started by jspd234 Parts For Sale
Started by DeMented Toys Toyota Pickup/4Runner Tech 1979-95
Started by greg_k113 Engine
Started by JOE 88 Toyota Pickup/4Runner Tech 1979-95
Started by Lugueto Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
