Reply #1 on: Dec 29, 2005, 09:38:54 PM »
A W46 is a early style 4 speed trans that would not stand up to 300 hp.
I belive it shares the same bellhousing to transmission bolt pattern as the early L43 so i dont believe that it would bolt up to the W56-58 bell.
I will double check in the am when i get to the shop
Marlin
Logged
