so yesterday, im driving around, everything is fine.... well the next minute i cant shift my truck into gear, any of them.... tried double clutching, everything.....if i force it really hard, i can get it to go into gear... here is the the kicker, i can force it into gear, come to a stop light be stopped, foot on the clutch and its fine, take my foot off stopped and it will die...ugh!
... i have seen an oily substance that i cant figure out what it is dripping down the inside of the cab near the cowl and going to the floor right about where the footrest dead pedal is left of the clutch.... hmmmm i think thats my clutch master leaking... is there a way to test that before i spend $ on it? its level is ok, but a tad low.... later tonight, early tomorrow morning i will pull it into the garage and start playing with stuff....
the clutch master is never empty, but i do top it off regularly..... ita about 1/4" low right now, and according to the side of the reservoir ahs about 2" of safe zone
If it is running down the drivers side firewall, inside or out it can be only 1 of 2 things (well it could be both) but since the brake master is not actually bolted to the firewall it is more than likely the clutch master. If it were the brake master you'd see it on the booster before it got inside. If you are constantly filling 1, the other, or both then that would be the one leaking. Of course if you ar putting a drop or 2 everytime you service your truck then that's just the brakes/clutch adjusting as the wear. For the most part you shoul almost never have to add to the clutch master or it has a leak.
so about the fork not returning to the depressed position, is that normal? or is the hydraulic system messed up?
Started by 91 super yoda Toyota Pickup/4Runner Tech 1979-95
Started by J-BO Engine
Started by 1986xtracab Toyota Pickup/4Runner Tech 1979-95
Started by myyodaisbetter Toyota Pickup/4Runner Tech 1979-95
Started by AaronB Transmission/Clutch
