shim size
Started by yotacrawler4, December 03, 2005, 11:53:15 AM
yotacrawler4
i was wondering what was the thickness of the original shims that go under the steering arms when u put crossover on , cause i lost my originals so i put some that came with the knuckle rebuild kit. i have no probs but i was just wondering. thanks jeff :turtle:
86' yota, extra cab, duals, HP frnt with detroit 4.88s, V6 rear with detroit 4.88s, bobby super set, driveline tech dl's, neat lil upgrades on the way can someone say 4link and dovetail front...
kyle_22r
there's 3 different factory shim thicknesses and it also depends on how many were there.
the consensus is that nearly all axles came setup with 1 thick and 1 thin shim under each steering arm and the same for under each lower cap.
if you have a little more wear then a .010 shim added in doesnt hurt,  just keep things even top to bottom as close as possible
CTENG in KS
Quote from: kyle_22r on December 03, 2005, 12:22:09 PM
Thats what I got on mine, setup was perfect for my hysteer.
