Project Land Cruzah
Started by Dooner, November 30, 2005, 08:31:17 PM
Dooner
More Garage Art! :thumbs:
Looka like the critters gonna have a nice flat belly as nothing is gonna hang lower than the bell housing. Shweet! :thumbs:
"Project Land Cruzah" In Land Cruiser Section
71 FJ40 327/465/ 4.7 Mini T/c, Trussed, Armored Mini Axles w/ High Cross Over, Aussie Lockers & 30 spline Longs.  p/s 35's, SOA, , .  86 Burb D-60 14 bolt 350/400/205 37's.  02 F350 Tow Barge, Toyo 38's, Banks 5" Wicked wheel turbo, Edge Juice w/ Attitude, Blah Blah Blah
gotrocks
lookin good, wish I lived closer so that marlin could work on my stuff
CruzrDave
Quote from: Dooner on December 11, 2005, 12:10:15 PM
Had a chance to play with the Critter the other day so I copied Cruiser Dave and did a little frame welding! :flamer: Still need to box in the rear frame horns though.
On of our customers sells a kit to box in the rear frame. Its laser cut 1/8" plate and also comes with a gusset for the rear spring hanger. I plan on buying a kit next month. Here is the link http://www.tlcconcepts.com/index.html
BTW, Looking good!
Taking back America, one part at a time! :madeinusa:
Dooner
Thanks for the link Dave, that kit looks like a must have. I was planning to cut out my own but this will save me time and a stack of cut off wheels!
Thanks bro, Mike
Dooner
Havent posted in a while so heres a little update. Got some new mirrors and half doors for the 40. The mirrors came from Cool Cruisers and the doors from SOR :)
Dooner
Whittled out a slave cylinder bracket today. Tried to keep it as simple as possible, its got a couple of ears welded on the inner side to take the bellhousing to engine bolts. Its got a bit of angle bent into it to clear the oil filter boss on the motor and to keep the slave rod aligned. Ill gusset the bend once im sure its dead on.
Hope it works! :crossed:
Mike
unclejpl4x4
Dooner
Tell you what, Ill give it a coat of Oakie Chrome when its finished just for you!
motorider228
I was wondering what you have to do to go from a passenger side drop rear axle to a center drop in a cruiser? just transfer case? or tranny and tcase? or is there more to it?
Hammerhead
Use
Quote from: motorider228 on March 12, 2006, 10:01:39 PM
Just use a mini case behind your Cruiser 4spd.
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
brc
1999 CTD 2500 Sport TST/MBRP/AFE/K&N and Quadzilla 315's yada-yada-yada
1985 Four runner 5in lift 35's lockers etc.
1973 FJ buggy project INWK 3RZ SM420 Mini Axles and Aluminum tub/cowl building to be light weight
Dooner
Thanks for the encouragement, not a whole lot of exciting stuff going on right now, mainly just resealing the 327 and some wiring work. Still have a ways to go. Aux fuel tank, fab up a t case x member, chromoly axles, radiator, Family cage, rear bench, brake lines blah blah blah! :blah:
Mike
brc
Do you have your rear bench seat?  Just wandering when I did my 40 I looked and looked for one I liked.  I ended up going with one from Steel Horse.  I made mine so the back flipped down and the whole seat flipped forward.  It works pretty well I used a mount of off a old K-5 Blazer to secure the back.  It works pretty well.  Just a thought if you do not have one already.
Dooner
Nah, dont have one yet, I have the fold down factory seats that mount on the fender wells and was gonna use a set of Subaru Brat seats but they are unpadded. Thanks for the tip on the blazer mounts, ill check them out.
Mike
Dooner
Finally got some time freed up to work on the Cruiser :greengrin:. Picked up a new tach and clock to match the rest of the cluster.
Dooner
Heres a shot of the Chevy clutch pedal modified to take the FJ60 clutch master. Heres a shot of my 4runner brake booster, FJ80 brake master and FJ60 clutch master all nestled together in a tight little bundle! :eyebrow:
Dooner
Picked up a short shift setup from Marlin for the Toybox. This will help as the 465 shifter base was quite a bit higher than the T case.
Dooner
#47
Got a little more work done this week beefing the front end with truss, Knuckle ball gussets and diff armor. Decided to rebuild knuckles just for peace of mind. Glad I did cause it turned out the bearings were shot. :greengrin:
Dooner
Christmas came early this year! :santa: Got my 30 spline longs and my Alloy USA rears! :rockingout:
freds40
With 35s those axles should hold up real nice.
"between projects"
Dooner
I think ill be in good shape, back when I started this build, Rocky and Dean :turtle: assured me that this setup would be solid. Bobby shows some big numbers for the 30 splines and the Alloy rears come with a 10 year warranty :thumbs:. I have the Aisin hubs that im gonna stuff with Longs hub innards. Should be dialed in after that. :burnout:
Dooner
Been giving the T case crossmember some thought. LC Owner said he was going with a crossmember using a Front Range design. I gave them a look and decided to go that route too :beerchug: to LC O. Front Range offers thier polyurethane mount bushings separate so I bought a set from them. Had I realized that they sold the Cross Member Center Plate, I would have bought one of those too :smack:. Anyhow I made my own Center Plate out of 3/8".
Dooner
Heres one mounted. I cut it out sort of diamond shaped because I wanted to have plenty of material to bolt and weld the arms to.
Dooner
Heres what Im thinking about doing with the Crossmember. Two 1/4" plates for the lateral arms sandwich the Center Plate with 2 plates of 3/8" across the top of the arm plates, laying horizontal.
Dooner
Got another piece of the puzzle today! BudKing hooked me up with the 4.37 third ive been looking for  :beerchug: This ones for you Mike! We made the trade over at Marlins and got a quick look at the expansion project. :turtle: Things are really looking up! :yesnod:
LCOwner
Glad I could provide the motivation for the cross-member.  :burnout:
'71 FJ40, 350 TPI/420, 4.70/mini, 60's/5.38/42's, under construction.
'83 FJ60, SOA underway.  Soon to have a Police 350TBI/700R4/.....
Hill Hoppers Central Valley 4 Wheelers - Founding Member
Four Wheel Drive Club of Fresno - #1127
Dooner
Got back to the garage after a short break  :thumbs:(durn near a year!) Anyhow got some work done on the T Case X member.
Dooner
Did a bunch of measuring :think:, cutting, spot welding and trial fitting, coming right along
Dooner
A little Chevy orange to top things off, still need to build the frame mounts, Then ill be able to move on to the drive lines.
unclejpl4x4
:woohoo:   looking good bro    i love how the dash looks
