low oil pressure
Started by yotacrawler4, November 30, 2005, 02:53:19 PM
yotacrawler4
man i have a newer motor maybe 10 or 12 thousand on it, and i have very low oil pressure, it dont make any engine noise, theres now power lose, so what could it be, i dont really want to rebuild the whole thing, so can i just change the oil pump, or take the oild pan off and change the bearing if thats what i could be. :turtle:
86' yota, extra cab, duals, HP frnt with detroit 4.88s, V6 rear with detroit 4.88s, bobby super set, driveline tech dl's, neat lil upgrades on the way can someone say 4link and dovetail front...
All_Set
What is "really" low oil pressure?
Oil pressure for 22 motors is 4-60 psi is normal.  Pressure goes up as you increase rpm.  But @ idle, 4psi is normal.
bmxanddie
i have the SAME EXACT problem (22re). at idle i have none or really low pressure. Then when i'm on the throttle it gets like maybe 65% up on the guage....
yotacrawler4
well i have the dash with the sr5 dash, so it has the oil gauge and when im at idle its like the damn truck is turned off, but when i drive it or its above 2000 rpm its right below the first little line on the gauge
Do either of you have a REAL gauge on it?
Duffil
ya, put a manual gauge on it, that'll tell you whats actually going on.
Uncle Jesse
my hybrid with 10/40  ,after drive a few miles  ,like to town then stop at a light it comes down to about 30psi,   cold  it may peg 80psi
typical down the road psi  is 50-60
Prismo
Mine runs ~55-60 on the road & 15 to 20 at idle when it is warm. I am using the turbo oil pump so it has a little more at idle. Realize most of the aftermarket "turbo" oil pumps are reboxed regular 22re pumps. The only real turbo pumps I have found are from the dealer & lots of money.
Skinny_Pedal
on the topic....what are people using for manual gauages? preferred choice
Im an OG
Autometer, autogauge (cheaper autometer), VDO or even a cheapy sun performance is better than trusting a generic dash gauge.  I always gow with manual gauges too.  They are a bit slower to react to changes but they are more reliable and trustworthy in my experience.
Cheesemaker
Try a new sending unit, my nissan used to run 20 psi and now it's a constant 45 to 50 psi at idle or at speed!  I definitely would get a better guage, one with numbers instead of colored markings! If those don't solve it then I would look at the oil pump.
Prismo
Sunpro mechanical guages. If you get a manual guage, spend a little extra & get an oil pressure guage with metal tubing from the guage to the sender boss. The plastic line will fatigue & break. It will blow a great deal of oil at speed. If you don't notice it immediately you could possibly ruin your engine. Luckily mine blew & sprayed oil on the windsheild as soon as it broke. Bought the better guage after that one.
David
I had a low oil pressure problem once on my 83yota. Turned out to be the fuel pump leaking fuel into the crankcase and diluting the oil. Might be worth a sniff or two.
My normal pressure is well over 20 at idle and around 40-50 down the road. :driving:
my 2 cents
brainlessfool
my 83 has 25 at ilde (hot) and about 70 @3K.
