Can say I agree, I put about 3.5K into mine and it do run good for a 22R. butt it's still a 4popper!
Can say I agree, I put about 3.5K into mine and it do run good for a 22R. butt it's still a 4popper! oh and I like my 32/36 just fine. The 38 is manual sec.s and that may not be the thing for towing.
i heard the 32/36 actually flows less than the stock 22r carb
Negative capn, a 32/36 flows 1 cfm more than stock. Stock is 325 cfm, weber is 326. If you had a stock carb that works well I'd leave it alone, but if you needed to rebuild it that's when I'd start lookin at the weber. They're dirt simple and easy to rebuild also.
Started by foxybluebird General 4WD Discussion
Started by BCB General 4WD Discussion
Started by AJ Project Research and Build-Ups
Started by jafish Toyota Pickup/4Runner Tech 1979-95
Started by jimbo74 Tow Rig and Trailers
