Front drive shaft help
Started by 4Runnerdude, November 02, 2005, 06:32:21 PM
4Runnerdude
 I have just finish installing my solid axle with Marlin 4" springs.    I don't know what to do or what drive shaft should I build for my truck.  Any help will be greatly apprecated.
MiniSimp
If you have the money ($400-600) go with Jesse at High Angle Driveline
http://www.highangledriveline.com/
If not, build a square driveshaft.
4Runnerdude
Can something be done to my existing drive shaft to achieve the proper drive shaft angle?
FIREBALL
Ya, install a dual case. Does wonders for drive shaft angle. The only other way to improve the angle is to rotate your pinion up, then cut and turn you knuckles.
Otherwise, what MiniSimp said is right on......High Angle (bunch-o-money) or square (bout 30 bucks)
freds40
If you have the angles right, your local driveshaft shop can rework your stock shaft. My local shop builds awesome shafts. I took them my stock CV shaft and they re tubed it and added 18 inches of slip shaft all for About $225
"between projects"
