Author Topic: Odd engine noise 22RE  (Read 5039 times)
94toytruck
  • Turtle Points: 175
  • Male Posts: 142
  • Member since Jun '04
  • kreepykrawler
    • rightcoast4x4
« on: Oct 28, 2005, 06:16:04 PM »
OK I have some issues after a bearing went bad on me. No.2 rod bearing was knocking really quiet soI shut it down and fixed it. Crank mic'ed out in spec and good clearance. Fired it up and let it run for 20 minutes to change oil and filter again. Was quiet the whole time and ran fine. After changing the oil and filter I left it running again. After full hot it starts ticking like valves loose but goes away after tapping the gas and comes back after a minute or so. I checked the valve clearance and its good. and they are good.
I cant find anything wrong anywhere. I've checked it over really good. T-chain is tight, valves in spec, no broken springs, Plenty of oil and no dirt. I actually pulled the valve cover and ran it cause it sounds like its running dry on 1 or 2 rockers but its not.
The really odd part is it seems like its getting better :headscratch: . Just wondering if anyone ever heard of something like this.
95 x-cab truggy, 39 pitbull's on KMC's and 60/14b with chromo's, ultimate duals, linked and Co'ed
www.rightcoast4x4.com<<<get it
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
Re: Odd engine noise 22RE
« Reply #1 on: Oct 28, 2005, 06:46:38 PM »
lol a quiet 22r  :laugh:   I don't think i have  owned a 22r  that did not sound like a train
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
« Reply #2 on: Oct 28, 2005, 08:55:00 PM »
what he said.
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #3 on: Oct 28, 2005, 09:14:17 PM »
i agree with both of them.....
Shamb
  • Raisin in the making..
  • Turtle Points: 133
  • Male Posts: 3,414
  • Member since Oct '04
  • Proud Parent
« Reply #4 on: Oct 29, 2005, 09:17:59 AM »
94toy what year is that 22RE?
My 88' did the same and was told that they ALL do that, nothing to worry about. I know a certain year toyota they machined the block out of a different type of metal so when it expands and retracts it'll cause noises and also oil lose!
Just my  :twocents:
rexandfx
  • Turtle Points: -7
  • Male Posts: 50
  • Member since Oct '05
  • hill-billy ramp travel
« Reply #5 on: Oct 29, 2005, 09:20:39 PM »
Did it actually spin the bearing? reguardless you now have metal shavings in your oil journals. and other bearings.
I am 99% sure that it's that same rod bearing your hearing.....not your valves.  It WILL go away with slight throttle.
86 4runner 22rte- stock...for now
81 jeep cherokee widetrack fullsize- also stock...for now
94toytruck [OP]
  • Male Posts: 142
  • kreepykrawler
    • rightcoast4x4
« Reply #6 on: Oct 29, 2005, 10:46:29 PM »
Motor never made noise like this before. The bearing was wasted but not that bad(copper but not torn up) and crank was fine as well as the clearance with new bearings. It just barely started making noise and was shut down.
The noise is deffinitly coming from the top end. I looked close at the valve adjuster ends and they are pretty worn. They should probly be changed but I dont think that is the noise. They are original an have 140k of hard miles on them.
There was almost no signs of metal in the motor before when the bearing went bad. I split before the old and new filter to check. I had removed the valve cover before tearing into this to check for metal and found none.
Before when I started hearing the rod knock it was only if it was reved and decelled. Its a totally different noise now. Deffinitly not a rod knock. Oh and if it was a rod knock it wouldnt be getting quieter the more it runs. It now will actually come and go. I let it run tonight and it went away for awhile then came back but not as loud then went away again.
Oh yeah it a 9422re with a dual chain metal backed guide setup in it. The rest has been made stock again awhile ago.
rexandfx
  • Turtle Points: -7
  • Male Posts: 50
« Reply #7 on: Oct 30, 2005, 12:05:10 AM »
if it didn't damaged the crankshaft or the rod journal. sounds like you caught it before it went fully through the bearing then.
How did the bottom of the oil pan look, right at the pick-up? any metal there?
Hope you get it figured out :crossed:
yotabj
  • Turtle Points: -15
  • Male Posts: 116
  • Member since Feb '05
  • MAD FLEX YO!!!!
« Reply #8 on: Oct 31, 2005, 07:23:11 AM »
Wrists pins perhaps...my rattles like that  when you first start it up,when i rev mine up past 1900 rpm mine goes away...If i'm in a trail it will rattle all the time unless i'm in the gas.I have new bearing,rings t.chain,oil pump I have 65psi the only thing that hasn't been changed was my wrist pins..they'll run forever like that tho
'84  Truggy EFI swap ,5.29's Detroit,welded,Dual Ultimate Cases,22re,3 in. downey,4 in.Marlin Front springs on back  114 wb ,39.5 Rockers,30 Spline Longs
94toytruck [OP]
  • Male Posts: 142
  • kreepykrawler
    • rightcoast4x4
« Reply #9 on: Nov 02, 2005, 10:29:14 AM »
I took it out this weekend. After a half hour cruising through PAP I let it idle and no noise. Havent heard it make any noise since then.
I beat on it pretty hard this weekend with no issues. I even had the full throttle assault to get it off its side and its still nice a quiet :thumbs:
Drained the oil and no metal particles anywhere in the oil,filter or on drain plug :thumbs:
Shamb
  • Male Posts: 3,414
  • Proud Parent
« Reply #10 on: Nov 03, 2005, 08:57:48 AM »
I've owned many toyota that had this really light "tap" typically its louder in the morning when she's warming up but they've ran for 100,000's of miles without any problems. I'm sure you have nothing to worry about.
toylife
  • Turtle Points: 139
  • Male Posts: 86
  • Member since Jan '05
« Reply #11 on: Nov 12, 2005, 04:11:05 PM »
i have a 81 toy with 419,583 miles a 87 with 212972 miles 93 with 203992 miles this light rattle is common . it is in all my trucks it goes and comes some times louder or you just get  use to it or learn to ignore it but it is ok.
only in a yota
94toytruck [OP]
  • Male Posts: 142
  • kreepykrawler
    • rightcoast4x4
« Reply #12 on: Nov 30, 2005, 09:08:19 AM »
Figured I'd update this. It has been quiet since way back when oil changed twice and no metal found.
Rebeltait
  • Member since Dec '06
« Reply #13 on: Dec 28, 2006, 12:27:03 AM »
can you run 22re with cover off?
94toytruck [OP]
  • Male Posts: 142
  • kreepykrawler
    • rightcoast4x4
« Reply #14 on: Dec 28, 2006, 05:53:24 PM »
Wow I almost forgot about this post. Engiine is nice and quiet since first run with new bearings. No metal ever found either. Its had the crap beat out it. Noise never came back even after being hydro locked 2 times and tons of full throttle hill climbs. Wish the dam thing would die so I can toss my SBC in there already.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #15 on: Dec 28, 2006, 06:18:42 PM »
you can if you dont mind  the oil  thats gonna be slung  all over by the timing chain
mudking82
  • Turtle Points: 62
  • Male Posts: 104
  • Member since Aug '06
« Reply #16 on: Dec 28, 2006, 11:27:40 PM »
Agreed, plan on cleaning up your engine compartment and the bottom of your hood if you do.
Last post Jun 03, 2008, 08:13:42 PM
by The Rooster
Last post Sep 16, 2008, 12:45:10 PM
by 83MT
Last post Feb 19, 2010, 07:40:26 AM
by crazykooter
Last post Apr 01, 2013, 12:05:57 AM
by Jr0mer0
Last post Aug 29, 2016, 03:55:30 AM
by Gnarly4X
