Suicide is painless
Started by toyhatsu, October 23, 2005, 07:03:07 AM
toyhatsu
I was leaving from work on Thurs. and I started getting a ticking/ grinding noise from my 3RZ-fe.  I had it towed to a garage and they found that one of the balance shafts had worked it't way out and destroyed the bearing race in the block...I'm pretty sure that's the correct explanation.  I had replaced the timing chains but not the balance shafts and bearings.  The engine had 140.000 miles on it and ran like a clock.  I was told that it was just a freak failure.  I was pretty upset as I had just spent nine months getting the rig going, drove it for five months and this happens.  I am in need of another 3RZ if anyone knows of a good used engine.  Preferably a distributor model.  Mine was a `96 Tacoma.
Thanks... :rivers:
1991 Daihatsu Rocky, 3RZ-fe, Marlin super heavey duty clutch and pressure plate, Marlin W56-C-HD, duals, Marlin twinstick, three link front with Fox AirShox, 35's, Toy axles, 5.29:1, ARB F&R etc.
dangit man, :smack:  that totally sucks i have seen deisel blocks with bad balance shafts bored out and a larger bushing installed,  not sure if you can do this on the 3RZ  but i would think you could
:down: :down: :down: :down: :down: :down: No way man... Your motor was really clean inside, wasn't it? I wonder why it failed?
Can you find 3RZs without any wiring on Ebay or somewhere for around 6 bills or so? Maybe not?
.............................. I dont even know what to say right now...... :down:
toyhatsu
BigMike,
Here's a pic of the spun bearing.  It was about midway in the block on the balance shaft.  Like I said it was a freak failure.  I did get another `96 with 48,000 miles on it and it's installed.  I noticed that I have more oil pressure with this one.  I was able to salvage the intake, throttle body, fuel rail, injectors, sensors etc. from the old engine.  I did get a used W56D in place of the W56C.  This is a good one with no gear noises and it doesn't pop out of first :biggthumpup:  I'm still real impressed with the 3RZ and believe it is one of the best mods on the truck.
Just thought that I would let you know what happened for the record.
toyhatsu
swap pic
toyhatsu
I only have about 200 miles on this one.  Hopefully I can make the next roundup especially if it is in Moab.
Said it before but, I dig your rig man!  Even in stock form those things are kinda neat.
kyle_22r
anybody make a balance shaft eliminator kit yet for these engines?  i think they're a stupid idea for an engine that sees any serious use.
