Solid axil camber adjustment
Started by RunnerRick, October 21, 2005, 09:35:17 PM
RunnerRick
Can the camber be adjusted on a solid axial if so how? I have a 84 4-runner and if you look at the truck from the front the bottom of the wheels go in(negative camber?)and it is pretty noticeable. Both sides are even.
S-10 Stewy
Rick if the bottom of the tires are pulled in, this is positive camber.  In at the top .... negative camber.
Most shops I have talked with on this first want to bend the housing. (not sure if they want to do it for the $$$ or why :headscratch: ) but I personally do not favor doing that.  I have heard of a kit out there that is installed at the king pin, kind of like an offset cam but have personally never seen it.  My preferred option would be to shim the spindle  :clap: (if you can find shims to do this.... I think they are called cosmo shims) to get the desired camber.  Once it is in, no worries what so ever!!! :thumbs:
Hope this helps.
Stewy
It's built Chevy tough with Toyota stuff!
flyin ryan
I have this same problem.   I think I remember reading once before that it might have something to do with the trunion bearings.  It's more noticable with my 35" tires than my 30" tires.
Prismo
I have really been thinking about buying the oem tool to shim the trunion bearings correctly. I have 2 toys w/solid axles now so the 100 bucks is almost worth it. I know the axle in the 90 is not correct just by looking at the way the wheels set.
S-10 Stewy
When I had a buddy of mine truss my front (100% all the way across) he did not allow enough room for the fact that the fabrication he did would pull on the axle and it made both sides positive camber for me as well.
I think the trunion bearings your talking about are the same thing as the king pin bearings??????
Stewy
yes  the trunion bearings are what on a chevy or ford would be a kingpin
check your bearings befor doing anything weird like bending a housing :smack:
FIREBALL
Are you looking at it while the tires are on the ground? I've noticed that sometimes the tires will have the appearance of being out of camber after you've pulled up and parked. I found that, sometimes, the cause is too much toe in. It causes the tires to pull together and look like the camber is off. Jack up the front end and watch while you do it, the tires might slide outwards after the weight is off.
The other way to find out for sure is to take it to an alignment shop and have them check it for you.
If the camber is off, then your housing is probably bent.
RunnerRick
Thanks for the good info, I thought the housing might be bent too but why would it bend the tires in, and even on both sides. I did not notice this untill I put the 35's on too.
FIREBALL
If your toe in too much, it will cause this and it will do it evenly like you're discribing. The 35's just have more sidewall and may exagerate the problem more.
Yota4life
Jack the front off the ground and move the wheel back and forth to see if the wheel bearings have play or its the trunion bearings. I had this problem on my axle and found out the wheel bearings were just really loose. SO i replaced them and tightened them the correct way and its now fixed.
FIREBALL
ya good call
wheel bearings or trunion bearings
but check your toe in cause fireball has a extremely good point,  if those 35's are toe'd in a little it will actually pull the bottom of the tires in,  if the trunion or wheel bearings are worn at all this will cause what you are describing,,  get a buddy,  a jack and a tape measure,  jack up one side , or both  and then measure just below the spring in the rear of the tires,  outside of tread to outside of tread,  then do the same in front ,  you should be within 1/4 inch at least , with 35's  if not rotate your tierod,  to move the tow in/out as needed
S-10 Stewy
Yep .... or just go pay $19.99 to your favorite shop to have it done right and be done with it. :thumbs:
too much toe will wear the out side of the tires, giving the impression that it has "positive camber"
Stewy   8)
