Author Topic: how do you check to see if a housing is straight?  (Read 1688 times)
Tice
  • Turtle Points: 8
  • Male Posts: 881
  • I named my son Wheeler!!!!
« on: Oct 11, 2005, 05:48:43 PM »
I broke another longfield in Las Cruces this past weekend. :mad:  It was on the same side as the other 3, so I'm thinking my housing may be bent. Plus even after replacing the inner seal it still leaks. Does anyone know how to check a housing to see if it's straight or not? Thanks :beerchug:
www.wheelingarizona.com
musclesliver
  • Turtle Points: -36
  • Male Posts: 81
  • Member since Aug '05
  • huh??? Where am I???
level???
11 Bravo
  • Male Posts: 140
  • Chicks dig scars
I am not an expert on stuff like this, but since you aren't getting much advise I will offer an idea.
Try putting the axle into the diff without an axle seal in the housing. See if the axle looks very centered in the seal bore. You can wiggle the axle around a little and get a feel for where it is centered in the side gear, more or less just taking the weight off the end of it. By the sounds of your problem, it should show if the axle is pretty far off center.
I'm not very smart, but I can lift heavy things.
Tice [OP]
  • Turtle Points: 8
  • Male Posts: 881
I was thinking of something like that. Just didn't know if there was an exact way to do it. I've got another housing that I willl probly swap in this weekend. I need to tare the one thats in there now apart anyways.
actually it sounds more like a trunion bearing bad  throwing your knuckle out of line
if you just installed trunion bearings did you make sure your shims were evend out top and bottom,  if not thats your trouble,  bad trunions or shiming to much to one side will make birfs go and seals worthless
Last post Aug 14, 2003, 09:23:04 PM
by Bagged71
Last post Sep 27, 2004, 11:35:45 PM
by mudguts
Last post Mar 26, 2005, 02:18:18 PM
by mr4x42u
Last post Oct 15, 2006, 04:06:25 PM
by 79coyotefrg
Last post Nov 14, 2007, 07:51:06 PM
by Dooner
