I could still do 70-75 with 5.29's and 35's. That was about it though.Definetly go dual case!!!! You'll love it and you'll crawl over anything and everything and you won't have to touch your brakes going down hill.and I agree.....single best mod you can do.
not to jack the thread but what will 5.29's as opposed to 4.88's on the freeway? being my crawler is also a DD highway is also a concern to me as i am looking into doing gears as well. im running 35's on a 22R/5spd manual
i also forgot to mention this is also my tow vehicle for when me and my buddies head out to the dunes. thats why i am concerned about highway compatability. what kinda rpm's are you spinning at around 70-75?right now most i can do is about either 3000 rpm's in 4th, or 2400 in 5th. but it feels like a dog pulling them small hills.
Go to this page and you can play around with gear ratios and tire sizes and it will tell you the RPM you will get.http://www.csgnetwork.com/multirpmcalc.htmlAs another thought for you to get by on the cheap for a while, maybe you should pick up another set of wheels and tires for your highway driving. Running a set of 31's would probably work out pretty well for you on the highway until you have the cash to change your gears. Might look kind of funny with a 5 inch lift and guppy tires, but it is worth a thought.
really? you have the exact set up i want then! how involved was it to do your 4.7's? i know anything i do to my truck at this point can only help. running 35's, 5 inches of lift and 4.10's makes it a dog on the freeway. 5th gear is nearly obsolete unless its down hill with no head wind. gears are really spread appart and overall the gearing sucks.do you run a locker/spool/welded rear end? what rpms' are you at in 5th doing 70? do you like your coffee black??? ................. oh sorry for so many questions, haha!
install instructions are available from Marlin.com if you arent comfortable with machinging your case go with the 4.0 gearsyou still have to take you tcase completely apart, but the 4.0/4.7 might be the best idea
the 4.7 gears are nice but are more tech involved than the dual cases. but w/dual cases you have to do drive shaft work. Loose cannon has a very good rig and can drive daily without a prob. 5.29 gearing w/a 4.7 case will give you about the same crawl raito as dual cases w/ stock gears ( 95 to 1 w/ a 4.7 case / 108 to 1 w/ dual cases) the diff is pretty small. for the money I would go w/ 4.7 kit its not to hard to install and no driveshaft mods to do.With the 5.29 4.7 t-case you can do great on the trail but still drive on the road at 70 at about 2800 rpm.
Started by wheeloverhondas Chit Chat Camp
Started by rEdnECkwHeE1eR General 4WD Discussion
Started by BIG-T Engine
Started by sumedumbkid Parts Wanted
Started by Drachota Parts For Sale
