Stiff clutch
Started by paradisekid, September 06, 2005, 01:51:48 PM
paradisekid
On my 85 4runner the clutch gets stiff after moderate use on or off road.  I have tried to spray WD40 inside around the clutch and got behind the clutch boot near the frame and neither seem to help.  Is it time for a new clutch or is there something else I can do?
i bet it goes in partway fine then kinda binds up    if so your pressureplate is coming apart,   i strongly suggest a marlin 1600 NON CERAMIC
paradisekid
Exactly coyote, then the clutch will get tougher to press after constant use.  Sounds like it's time to replace the clutch and pressure plate.
SLOYOTA808
Quote from: 79Coyotefrg on September 06, 2005, 04:18:50 PM
Noticed you stated NON CERAMIC...let me tell you, my DD 93 IFS V6 is like a radical race car trying to run the ceramic clutch.  In my next lifetime, I'll opt for NON CERAMIC for my DD...
Quote from: SLOYOTA808 on September 07, 2005, 02:32:33 AM
:yupyup:   i've run ceramic clutches in big rigs and i would N E V E R buy one,    1600  NON CERAMIC      and your golden
