\custom built toyota truck bed trailer 1992 bed -has hydralic surge brake hitch using all toyota hardware(matercylinder ,brake lines,factory drum brakes on toyota rear axle assembly- it also has the factory park brake- it also has an aditional saftey brake system if the trailer comes loose from the tow vehicle it will activate the brakesthe trailer is very well balanced and can be moved easily with one hand (easy to hook up)the factory efi fuel tank can be mounted in the cradle and you wont need to carry those nasty fuel cans ,just pull up next to it and use the fuel pump to refill your tank(battery not included) kitchen sink not includedi also have three custom aluminum rims for it (sexy)factory toyota rear lights-spare tire carier-bed liner-also have campershell for it in the front of the bed is space enough to carry a motorcycle ,or quad,(will customize to your needs)or tool boxes,bbq,or set up the tongue with a outdoor kitchen ,great for those weekends in the hills so your truck does not have to carry aal your gear on the trail -with the shell on you also dont have to deal with the elements if you wanted to leave the tent at home600.00 as is or for a few dollars more i will customize it to fit your requirements ex: quad or motorcycle rack and rampscontact grumpy(mike penner) at 559-855-3443 anytime -or e-mail me at grumpy1@netptc.net but i am missing alot of e-mails so its better to call the possibiltys are endless for what it can be used for -blah blah blah
Started by grumpy1@netptc.net Parts For Sale
Started by toyman151 Parts For Sale
Started by Trailtoy83 Parts For Sale
Started by Kel3283 Rig Gallery
