motor swap on a g52??
Started by confused, August 28, 2005, 07:37:37 PM
confused
i have a 1984 toyota with a 22r and a g52 trannie. i recently bought a stright 6 out of a 84 supra and was wondering if the transmission could take it. i believe the hp is 155...
Marlin
No.
It would be marginal at best.
The G52 has a 80 by 20 mm wide input bearing that has a wimpy input to countershaft gear set.
A better choice is the G54 trans that has a 23 mm wide input bearing and a stronger gear set.
The W56 is stronger yet, with the R series trans being the proper one to use behind the six cylinder powerplant.
