fender trimmin
Started by GrenadedToy, August 26, 2005, 11:45:53 AM
RHG
Sweeet, I will have to remember that. What springs are you runnin? looks like rears up front and chevies in the rear???? Do you have a close up of the hanger you built?
Ramrod
if you want to check out my hanger look for my build up it has a few pictures of it.  for springs I have 5rear leafs up front and it is way to soft and I don't have enough up travel on my shock and I bottum out really bad so before the roundup I am putting in two more leaves up front
RHG
too soft? Hmmm, I will probably be using rears up front. Would Marlins shock hoop allow you to mount the shock higher for more up travel?
Ramrod
Yah they are to soft because I only have 5 leafs when most people run 7.  I also have 4" of compression for the shock because they are so long.  but I now got two more leafs to trow in there hopefully today.  One in a 72 chevy nova rear main and the other is the main from a front 2 " lift pack.  both are really soft with some good arch so they should work perfect.
