what axle to use?
Started by miks85yota, August 23, 2005, 10:41:25 AM
miks85yota
i have an 86 ifs rear, and i want to put it in my 85, but the 86 has an auto tranny, and the 85 is a 5spd, just wondering if the ratio  will be the same front and rear after the swap, heard the gears lower with auto tranny,thanks
89 toy
look at the color on the end of the pinion. or pull it and count the teeth. if its not the same ratio just put the third out of the 85 in the 86 rear.
4.30 for auto,  4.10 most others
sent you a PM
miks85yota
yeah thanks, i guess ill just swap thirds anyway, easy enough
crawlerdan
Quote from: 79Coyotefrg on August 23, 2005, 12:08:26 PM
sent you a PM
i have a v6 4 pinion 3rd with 4.30 gears...any takers??
