alingment
Started by yotacrawler4, August 22, 2005, 03:39:53 PM
yotacrawler4
what is the best way to aling the front end of my yota, i got 35 toyos and 1 1/2 wheels spacers and crossover steering and i cant get it alinged totally perfect like i would want ,help me out here  :help:
86' yota, extra cab, duals, HP frnt with detroit 4.88s, V6 rear with detroit 4.88s, bobby super set, driveline tech dl's, neat lil upgrades on the way can someone say 4link and dovetail front...
FIREBALL
Marlin taught me a little trick years ago. Jack up the front end so the tires are just off the ground. Then set a jack stand in front of one of the tires and using a ball point pen resting on the jack stand, rotate the tire and make a pen line all the way around it. Repeat on the other tire. Now you have 2 parallel lines to measure from.
Take a measurement from the front, then one from the back side. You should be between 1/8" and 1/4" toe in, in the front.
yotacrawler4
thanks for the info, thats something that i never thought of thanks again
mr4x42u
spraying white paint on the tire and then using the pen helps make the line show up a little better..don't worry,,the paint won't last long..
yotaboy79
or just use a paint pen :biggthumpup:
I just put a staple in each tire and spin them around front to back as needed.  The staples allow the tape measure to grab onto the other tire so I can do an alignment myself. ;)
