So it is most likely the valve seals causing the problem, simply adjusting the values wouldn't correct the oil consumption?
spend $30 for a valve spring compressor, thread a piece of airhose into the sparkplug hole for the cylinder you want to work on , pressurize, then remove spring ,install new seal, reinstall spring, then move to next cylinder,yes it needs to be on the compression stroke,
Started by Destruct O Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by iNfErNaL « 1 2 » Chit Chat Camp
Started by jonnyrotten Toyota Pickup/4Runner Tech 1979-95
Started by w1cked Transfer Case/Drive Line
Started by Wainiha Chit Chat Camp
