exo cages in general
Started by surfindave, July 19, 2005, 06:45:36 AM
surfindave
Ok guys now we are getin to the nitty gritty.
What size pipe do you guys use for the frames?
What type of pipe? Seamless? Cold drawn ? Dom?
How much out from the body should i keep the exo??
I havent seen 1 in aus where i live so needd all the help i can.
Where so you guys mount too the chassis?
what happens with body flex and chassis mounted as in exo hitting the shell of the body ?
Thanks again
CTENG in KS
You will find people making them out of all sizes.
1.75 x .120 DOM or HREW is very popular.
Some like the 1.6 shedule 40 pipe style, very hard and rigid, tougher to dent than tube, but also heavier.
They look better the closer you can keep them to the body, yes there is the possibility of the cab bumping the exo in a roll, deal or add an inch of clearance.
The clearance may save your body, but it will also look worse, and create more drag on the road.
surfindave
Thanks Again CTENG
Having a good look now tho most pics arnt loading but i will get them .
Im just not sure what kindof clearance the cage needs its hard too tell from the pics does anyone know if like 40mm would be too far away or too close?
Thanks Dave
