Engine timing / Fuel Mixture Question
Started by blackdiamond, July 07, 2005, 11:43:01 AM
My problem is that ever since I installed my Weber Carb (4wheelparts.com - K874?) my truck only runs well on quality premium fuel.  It starts to ping and just run rough on even mid grade fuel.
I thought that my engine timing might be advanced and I might be able to retard the timing and run regular grade fuel.  The timing was, and is, retarded (8 degrees advanced rather than 12) so when I set it to stock specs the pinging got worse.
My next idea is to richen the mixture of the weber (not sure what jets to get) so that I can advance the timing and not run too lean.  If I understand things correctly, it seems like I should be able to get the weber rich enough to back off to midgrade fuel and advance the timing closer to stock specs.
Does this make sense to anyone or do I have my head in a dark place?  Any suggestions on what jets to get, I don't know what comes in them stock?
I make no claim to be a mechanic, but I am trying to learn.
germ
Get fuel injection!... just kidding had to say it
Erik :usa:
* Regardless of what happens, someone will find a way to take it too seriously.
* 2% rule: Must be 2% smarter than what your working on.
* If you make something even a fool can use, only a fool will use it.
* I've been crapping in the woods longer than lil'buddy has been alive!
Uncle Jesse
Where does it say that the timing should be 12 degrees advanced?  If I remember correctly on my 84 I ran the stock 5 degrees of advance, then with the idle advance hooked up to the distributor it went to 12.  The actual distributor timing should be 5 degrees though.  I ran a weber on that truck and ran midgrade.
It looks like I don't have the paper with the custom weber jet sizes on it either.
Quote from: Uncle Jesse on July 07, 2005, 05:10:52 PM
Sounds like there is more to know, I thought my service manual said 12, will have to look.  I don't have any information on Weber Jets, can you post it?
mudmaster
Is it the 32/36 Weber? My runs great with it on regular (lowest grade) fuel. Is it adjusted properly? If not try this site: redlineweber.com   It's what I used and I've had no problems for the last 4 years.
Time to go wheelin!
Quote from: mudmaster on July 07, 2005, 05:42:07 PM
It is a 32/36 carb, I think it is a K874 kit but not positive.  The only real adjustment on it is the idle mixture screw and it runs fine at idle.  I really think that it is just running lean, but I don't know what jets are in it to know what jets to get.  I have used that site before, but will look again.
mudmaster
I got my used so I don't know what jets are in it. I thought there were 2 adjustment screws? It's been a while though. Good luck
Time to go wheelin!
Quote from: mudmaster on July 08, 2005, 11:18:15 AM
I am pretty sure that there is really only idle adjustment screws, I have been working with tech support off and on for a while, but I have been wrong before.
Ferg
79-82 - 8* BTDC @ 950 RPM vac adv off
83 - 5* BTDC @ 950 RPM vac adv off
85 22R - 0*BTDC @ 950 RPM vac adv off
85 22R-E 5* BTDC w/terminal T grounded
Some idiots are too busy knowing it all, to ever learn anything...
Quote from: Ferg on July 08, 2005, 03:40:46 PM
Thanks, what does BTDC stand for...I'm not the sharpest tool in the shed?
Uncle Jesse
btdc=before top dead center
I ran a used weber as well, and the guy I bought it from helped me rebuild it and jet it.  I couldn't tell you what the jetting is though.  They do sell a weber carb that is pre jetted for toyota 22r's, so go searching for that info.  To find out the jet size I believe you'd have to get into the carb and look on the actual jets.
There should be both an idle speed and an idle mixture adjustment.
Quote from: Uncle Jesse on July 08, 2005, 05:35:13 PM
You are correct about the two adjustments, I have played with both of them.  Now I am working to get the rest of it up to speed.
Uncle Jesse
I just found some info I had packed away in the corner.
On my carb, this is what I ran:
Float Adjustment - 19/16" or 41 mm
                           2" or 51 mm
Main Jet - 130
Secondary Jet - 155
Emulsioning Tube - F50
Primary Air Corrector - 175
Secondary Air Corrector - 190
I also have a scan of an exploded view, parts list, troubleshooting chart.  I'll post a resize of the exploded view.  Let me know if you need  any of this, I will scan it fullsize then email it
Duffil
it would be a K8749 if I remember right...but Weber has been on strike for like 16 months now...the supply of 033B carbs has been depleted..i couldn't find one anywhere between Cali and NYC...
llamas
if it helps i live at 4800' ele. and use .115 main jet runs great i got jets from CARBS UNLIMITED 1800-994-CARB  good luck!
don whitman
Quote from: llamas on September 28, 2008, 07:25:23 AM
Impressive reply...over 3 years after the previous post!  That truck has been parted out.
BLACKDOG
Quote from: blackdiamond on September 28, 2008, 10:29:54 AM
:rofl:
bd is getting sassy of late!!  :gap:
              -Ronald Reagan
Quote from: BLACKDOG on September 28, 2008, 02:01:15 PM
:rofl:
Not really trying to be sassy, but this newbie shouldn't ever be accused of not using the SEARCH feature!
boobap
An eye for an eye makes the world blind.
