Author Topic: sas questions Quickly please  (Read 1348 times)
93Toyforme
  • Turtle Points: -16
  • Member since Jul '05
« on: Jul 02, 2005, 07:10:27 PM »
 :rivers:  ???  ??? i need some help understanding the SAS instructions for marlins kit. the frame tubes are to be centered then pushed out 1/4" ??? Which direction is that to be pushed out? toward the outside frame rail or inside? and the shackles are straight not the bent ones as pictured, they came with spacers, i asume for the bottom spring side, however the bolts are not long enough for them. Please help clearify this if you can. thanks
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: sas questions Quickly please
« Reply #1 on: Jul 02, 2005, 07:44:01 PM »
im not familiar with the sas kit,      sorry
  • Administrator
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #2 on: Jul 02, 2005, 11:51:35 PM »
I just called and spoke to Dave, and he says he did it a different way.
You can measure the width of the frame and compare that to the spring hanger, but instead, what Dave does, is he welds on the front hanger, bolts the leaf springs on, bolts the shackles on the springs, and then over the frame tubes. Then square the leaf springs up to the front spring hanger, and where ever the leaf springs position the frame tubes, weld them into place after you remove the shackles and bushings.
93Toyforme [OP]
« Reply #3 on: Jul 03, 2005, 12:52:51 AM »
thanks I'll try that, just want to make sure i do it right the first time.
Marketing
  • Turtle Points: -30
  • Male Posts: 1,639
  • Member since Aug '03
« Reply #4 on: Jul 05, 2005, 10:23:28 AM »
Push the frame tube out 1/4". That is from the center of the truck. So push it to the outside of the frame 1/4"
Last post Jan 27, 2003, 05:52:22 PM
by BigMike
Last post Jan 28, 2004, 11:53:49 PM
by 84runner
Last post Sep 13, 2004, 11:23:49 PM
by jvministries
Last post Nov 16, 2004, 10:30:09 AM
by HFCRAOffroading
Last post Feb 21, 2005, 10:09:12 PM
by awhotrods
