22r carbs w/ high angle idle???
Started by schlager_me, June 12, 2005, 11:55:36 PM
schlager_me
Are there any carb's out there for the 22r that will idle at 45 degrees?
(I am looking for something similar to the 'holley truck avenger' carb..... but obviously for a 22r).
Thanks.
crawlerdan
hey partner, i had the perfectcrb on my 22r, it was a brand new, not rebuilt , aisen carb from toyota of japan, about 450.00, and i sent it to holly and had them modify the crap out of it so that it would flow more fuel and air, because i had a lc engineering strocker motor. and odly enough, it would almost run upside down, infact on a few occasions, i rolleed onto the side and kept driving long enough to roll back onto the tires. in the end the carb cost me about 700 dollars, but i think that it was worth it. hope this helps :beerchug:
kyle_22r
stock carbs work the best.  lower your fuel pressure, run a catch can for the bowl vent, and maybe step up to a hotter ignition(MSD isn't a bad choice, helps burn a pig rich fuel charge to keep from stalling)
b_ripper8
Seems like propane is becoming the way to go if you want to keep a carb setup.
In Progress: 3RZ-FE Swap Underway.
Currently: 87' 4Runner - SAS - 5.29's - welded rear - Dual 2.28 cases - Optima bluetop - round headlight conversion - FZJ80 grill - rattlecan paint job - trimmed fenders - Ranger hybrid springs front - Tacoma hybrid springs rear - schedule 160 drivelines 8" slip front - Marlin's crossmember - disk brake conversion
crawlerdan
shad
Yup www.gotpropane.com if I don't do a supra 5mge swap I am definately going for propane.
86 Toyota 4 runner
My cardomain page
