Marlin Double Steering Arm
Started by digitalferg, February 22, 2003, 01:59:12 PM
digitalferg
Is the double-steering arm for the mini's the same as for the later 40 and 60 LCs?  I know the knuckles are the same for the 79-85 (right?) as they are for the 1980 and newer LCs...but what I can't find info on is if the TREs all have the same taper etc.  Specifically, can a FJ60 TRE fit into a mini truck steering arm?  Anyone?  Anyone?
2003 DoubleCab Tacoma
#1
Cruzila should have all the info on this..
I know that you can convert disk brake cruisers to minitruck knuckles/outters, and then your set for the steering parts you need.
Regards,
cruzila
#2
I believe that 79 up was all the same taper FJ40 FJ60 FJ80 and mini up to 86.
