lift for an 83
Started by thebigl2005, June 05, 2005, 12:31:02 AM
thebigl2005
what do you mean by cross over, im kinda a yota virgin
Crossover steering puts both your tierod and draglink above the springs.  When you move the axle forward (HIGHLY RECOMMENDED!) the drag link becomes too short.  So its best to convert to a ifs steering box and go crossover steering.
toybuilt
Quote from: WHITE_TRASH on June 18, 2005, 10:07:26 PM
I thought that was called High steer crossover
1983 Toyota Turned Chevy
Yup it sure is I was tired bite me. :hahaha:
yotaboy79
and the rears up front will give ya a little more droop than the stock steering can handle
thebigl2005
I have so pics I have been trying to post but for some reason when I go to submit it never goes though, like it takes forever to load the pictures I got
thebigl2005
also i want to go 35, But i dont have the money to re-gear. So i had planned on going 33s untill I could afford it, but some people are tellin me just go 35s and then gear it as soon as possible
crawlerdan
i run 33s with no gear mods, um, your gonna want to gear it asap :yesnod:
thebigl2005
Well i think I'm going to just go 33s cause i don't know how long it will be till i rear gear, i do work at shucks.
thebigl2005
had a guy come into my store tonight and offered me 32inch pro comp mudders plus rims, and a full bed for 500 bucks, so i think i found my tires for now
toybuilt
I ran 35's on a stock geared 83 toy it wasn't that bad, you get used to driving with them. It doesn't heart your cluch to much if you use it right.
thebigl2005
sorry, I've been kinda busy with work and I'm trying to start a business. Well my clutch is kinda weird, it catches right when you let it off just a little bit, I think if i bleed the system it would work allot better. One thing I'm worried about is my gears, someone told me it would fry em?
toybuilt
The only thing you would fry is your clutch, and thats only if your mean to it.
crawlerdan
grrrrrrrrr, you tell that clutch!....kinda like you where, captain 4th gear? :rofl2:
toybuilt
Quote from: crawlerdan on July 06, 2005, 11:24:27 PM
shutup  :driving:  :burnout:
                         :burnout:
thebigl2005
so would it be best to re-gear and lock up, before i do the lift and tires
shad
#76
Yes regear and lock it. Get some cryo treated longfeild birfeilds if you can't affrord chromo ones.
If you lock it up front you are gonna need stronger than stock birf's.
Quotehad a guy come into my store tonight and offered me 32inch pro comp mudders plus rims, and a full bed for 500 bucks, so i think i found my tires for now
I dunno bud tire deals come and go all the time I think you should hold out. After you get them 32's you won't be happy and want bigger.
86 Toyota 4 runner
My cardomain page
toybuilt
You can go either way tires then gears or gears then tires. It doesn't heart anything
yotaboy79
im running 35's and stock gears it isnt to bad
thebigl2005
yea, cause i have the money for the tires and the lift, but it might be like a month till i can get my gears, but I'm worried it might screw something up like me drive line or such.
I have finally decided with 5;29's and I'm thinkin about a spindle (not to sure what the right name for it) in the rear and a locker up front, but i would have to go back and do that after the re-gear
crawlerdan
thebigl2005
It might not be called a spool, that what was said to me I think it might be a spindle? not to sure, its like welding the gears.
crawlerdan
toybuilt
thebigl2005
Yea, does anyone have an opinion on them? Because I've heard that they work great, then I have heard that there not good if you drive you car everyday.
Can I fit 35s with only a five inch lift?
thebigl2005
toybuilt, what do you have done to your yota, very nice
toybuilt
Quote from: thebigl2005 on July 14, 2005, 04:47:26 PM
Well I had built up 22r, w56 tranny, dual cases with a 4.7. For axles I have (but there for sale) a narrowed Dana 44 in front and Dana 60 Toyota hybrid in rear. I have a 2 inch body lift and a 6 inch suspension lift, that includes 64 inch Chevy leafs in rear and rancho 44044 wagonnears in front. I have 36x12.50x15 inch TSL's.
I'm putting in a Dana 60 and 14 bolt with a 4.3 Chevy v6.
toybuilt
Quote from: thebigl2005 on July 14, 2005, 04:44:54 PM
You should be fine with 35's and a 5 inch lift. A spool does work great and they don't cost as much as a detriot, but they do tear up your tires more when you go around corners. Spools have no give its just like if you welded it up.
thebigl2005
well see I'm not thinkin of just to start off go with a six inch lift, on 33s. Then rear gear and lock up fornt and rear.
thebigl2005
my bad i meant im now thinkin off starting...
but anyways whats your thoughts about tires. I heard so many things about different ones i dont know. I was just going to go with bfg mudders.
