Author Topic: Idle mixture screw  (Read 1531 times)
oddball
  • Turtle Points: 1143
  • Male Posts: 952
  • Member since Jan '05
  • Weirdo
Idle mixture screw
« on: Jun 01, 2005, 05:49:08 PM »
My 85 truck failed smog today because of high HC and CO levels, the NOx level was low. It leads me to believe that its running too rich. Since the idle mixture screw had been tampered with I tightened it and then gave it 3.5 turns out. The FSM says not to tighten too much so my question is how tight is good enough? Also besides the obvious what else could cause it to run rich? The fuel level in the carb is a little high but within the maximum level.
2008 Tacoma regular cab, 4.88s, ARBs, crawl box, manual shift FJ case
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
    • PhotoBucket
Re: Idle mixture screw
« Reply #1 on: Jun 01, 2005, 07:20:06 PM »
you really only need to snug it up...anything further can damage it. you can "engineer" a vacuum leak by pulling the hose off of the valve that controls the hot air intake valve,which leans it out a bit,  that did it for me, also, check out this thread
http://board.marlincrawler.com/index.php?topic=1119.0
hopefully you went the pretest route!
oddball [OP]
  • Male Posts: 952
  • Weirdo
« Reply #2 on: Jun 01, 2005, 09:19:38 PM »
 I read that a couple of years ago but thanx,,,,,,,,,,,,Ill just try the mixture screw and hope its the problem
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • SimpsonBrothers.net
« Reply #3 on: Jun 01, 2005, 09:21:30 PM »
Also don't forget to adjust your TPS, make sure your charcoal canister is clean, adjust your valves, then....adjust your idle.
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
« Reply #4 on: Jun 04, 2005, 11:08:04 PM »
is it efi? if it is, you can lean the mixture by adjusting the mass airflow sensor, its easy and free.there is alot of sites on the web that will go through detailed how to
Last post Nov 12, 2004, 08:31:45 AM
by KYOTA
Last post Feb 04, 2015, 03:28:05 PM
by boobap
Last post Oct 10, 2008, 07:46:09 PM
by AaronB
Last post Jan 13, 2009, 05:57:39 PM
by emsvitil
Last post Mar 04, 2010, 07:28:28 AM
by dezrik
