Putting LC 3spd tcase gears into a 4spd case!!
Started by MD11Fr8Dog, March 26, 2003, 08:37:39 AM
MD11Fr8Dog
The part number for the idler cluster shims used when swapping  3spd tcase gears into a 4spd case are #36263-60010.  I threw those shims in and checked with a feeler gauge - right in the middle of the .004-.016 range!!  There are other shim sets as well - #36262-60010 and #36261-60010.  They are respectively thinner than the shims I used (not sure of the actual thickness).  I think they cost me about $4-5 a set from Toyota!
Also, make sure you use the orange bushings from the 3spd tcase, the 4 spd bushings are too thin.  See the pic below, from left to right - new 3spd tcase bushing, old 3spd tcase bushing, 4spd tcase bushing!  Big difference!!  You also need to use the spacer between the needle bearings from the 3spd.
Other things I did, I used the output shaft from my 4spd tcase (fine spline front output) and the front extension and housing (gusseted).  I used the 3spd rebuild kit from SOR, but the tcase topcover oil seal for the hi/low shifter in that kit will not fit on the 4spd tcase.  All the other bearings, gaskets, seals, etc were the same.
HTH someone down the road!!
 :greengrin:
Sean
75 FJ-40, 2F/SM420/ToyBox/3sp tcase, SOA, SR, 36" TSLs, fr/rr ARBs
ToyBox #007
cruzila
#1
Sweet! good info :thumb:
woody
#2
you do realize I'm just gonna pirate this info for a ih8mud.com tech writeup, don't ya??  :D
Brian 'woody' Swearingen ~ IH8MUD Inc.
MD11Fr8Dog
#3
Quoteyou do realize I'm just gonna pirate this info for a ih8mud.com tech writeup, don't ya??  :D
Actually Woody, I was gonna do a write with a few more pics, just give me a chance!! :bowdown:
Sean
ToyBox #007
woody
#4
I'll be patient then....
Done yet?   :greengrin:
MD11Fr8Dog
#5
QuoteDone yet?   :greengrin:
NO!! :moon:
I'll probably do it on my trip next week - going back to Kuwait City again!! :eek:
Sean
ToyBox #007
