15x8 vs. 15x10 w/37x12.5x15 tires
Started by coconut, May 31, 2005, 02:15:37 PM
coconut
i know this is gonna be a dumb question but I'm planning to give up my 15x8 wheels to a Friend who needs them for his 81...i got 37x12.5mtrs... will it be okay if i went w/a 15x10 wheel running the 37x 12.5 rubber i jus heard that if i went w/ a 15x10 wheel its most likely ill blow a bead when i do air down on the trail ...... :help:  :help:  :help:  :help:  :help:  :help:  :help:  :help:  :help:  :help:  :help:  :help:  ???  :confused:  ???
91 std pick up,3.4 swap, R151w/doubled up 4.7 in the rear, twin sticks, FROR x member,Marlins 4"sas w/ a 85 SA, high pinion ARB, 30 spline longs,chevy rear w/ ARB's and sitting on 36 iroks w/ beadlock speciality wheels
dirtbag
Quote from: crzyhawn91 on May 31, 2005, 02:15:37 PM
keep your 8's, you'll be much happier.
coconut
MiniSimp
You'll be able to air down your 8's a lot more than those 10's.
the 8's keep a bead better.
I got a buddy running 10's with 37's and he doesn't have a problem.  He airs down to about 8-10 psi and they do great.  But user preference i guess.
coconut
sweet tats what i thought 8's it is thanks fellas
I ran 37x12.5 ssr's on 10's and I never blew a bead once.  but I never took them below 10 psi because they would have slipped off. ;)
IronClad
ran my 37" mt/rs on 15x8's down to about 1 psi.. never blew a bead. hell i run 12 psi on the street.. keep the 8's for the 12.5" wide tires. 10's belong on a 15" or wider tire
Annihilation  Fabrication
Do you need a Hammer?
coconut
Quote from: IronClad on May 31, 2005, 06:55:07 PM
thanks guys i wanna get a sec set of tires too but i do want a wider stance what do you think?
RokCrawlinToy
Heres my  :twocents: , I have 37" MTRs on 15x10s  and air them down to 6psi and haven't blown a bead in over 2 years.
MiniSimp
Ridiculous, but here ya go
a 12.50 on an 8" wheel aired down to 0psi
Not much practical use, but the bead is still there.
UNBREAKABLE
Do you know whos truck that is? It has the 38" XML's
That's how I roll
camo89
2bigbroncos chapter from mishagan i beleve not shure on name
mopar parts
Volcom
Could I get away with running the 37*14*15 Irok on an 8 inch wheel?  Should I step up to a 10 inch wide wheel for that tire?
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
