Transfer case dissasembly
Started by mtnmalr, April 15, 2003, 02:12:47 AM
mtnmalr
I'm currently working on my son's 89 truck, we're going to install gear drive transfer with crawler gears but I can't figure out how to disassemble the gear drive transfer case. Seem's like shifting fork and rod might be problem. Am I suppose to drive the pins out of shifting rods? I have the back part off but can't separate the front from the center. I haven't purchased a manual for this transfer yet and am looking for some help. :smack:
Born with Land Cruisers, trying to learn about trucks.
trt2
#1
yes, you are going to need to remove those roll pins from the shift rods.
I suggest you buy Marlins gears which come with some directions...
also, its best to have everything there as opposed to tearing it apart, leaving it on the bench for a couple weeks, then coming back to reassemble it all.
have fun!
Tony
Round Up M.C.
Brandon
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
Brandon
#3
not sure what the 89 uses, but nearly the same - they aren't much different unless it is a chain drive
Brandon Miller
mtnmalr
#4
Thanks, that helped alot. :thumb: :beer:
