Bushing Sleeves...a little help pls!
Started by CTENG in KS, May 22, 2005, 02:15:48 PM
CTENG in KS
The sleeve inserts for inside the leaf spring bushings...anyone know where I can order up like a half dozen of em??    :hammerhead:
What exactly do you need?  the bushings or the sleeves that alloow you to use smaller bolts in them?  if its the bushings you need Marlin sells them.  If you need the sleeves to reduce the bolt size just go to a metal shop and find the appropriate size tubing.  Or you could just forget about it and drillt he shackles to 3/4" and run bigger bolts like I do. ;)
CTENG in KS
Any chance you know what size tubing that would be...?   :hammerhead:
Nope like I said I drill out the shackles and hangers to 3/4? and run large bolts.
CTENG in KS
OK, for anyone searching, this topic is a little on the old side, but I found the bushing sleeves...
Downey makes their own and has them in stock on the shelf.
www.downeyoff-road.com
